Fuel heater delete nipple bushing
Postby monoblock » Tue May 27, 2014 2:30 pm
The required shorter/close nipple for this project is Cummins # 3925954 .The Case IH part # J925954 is 1/2 the Cummins price.We know that from the archives but what about the correct O ring? I got a bit confused with the Case Interchange number for the "O" ring/seal -it might be 3834185S? The Cummins # is (?check) 3913695 or the seal from a Fram 3980 filter.
I found a mail order source for Case parts - RPM Machinery where you can plug in these part numbers for info but of course the freight kills the deal.But at least you can confirm part numbers.
http://partstore.casece.com/us/casepart ... #epc::home
Does anyone know the generic thread specs for this nipple/bushing? I'll forget about the internal hex. Loctite 2422 !
It would be great to have all these tedious little details in one place? Perhaps on this thread?So Please correct any errors!
monoblock
Re: Fuel heater delete nipple bushing
Postby CumminsPower59 » Tue May 27, 2014 3:44 pm
I used a Wix 51036 oil filter O-ring...works well. Its a filter for a mid 90's small block.
Postby monoblock » Tue May 27, 2014 5:52 pm
I found out why the close nipple is so expensive - it is M16 1.5 -yes a damn metric fitting on our old American truck! If it had been a 5/8 nipple it would have been easy but oh no ,they put a difficult size on.
Please let us all know if you can find a source for the M16 1.5 close nipple. I can't.
monoblock
Postby DodgeFreak » Tue May 27, 2014 6:23 pm
so are you wanting to delete the heater or replace the heater o ring?
Postby monoblock » Tue May 27, 2014 6:50 pm
Just delete the heater. It was not leaking and is in perfect condition .The nipple came out very easily - perhaps too easily? In Los Angeles we don't need a heater for the fuel!
So the delete nipple and O ring will allow the stock fuel filter to go back without the heater.
The only place I found for the delete nipple is Genos.
Here it is- $20 for a nipple!But hey - they've got it!
http://www.genosgarage.com/FUEL-PRE-HEA ... 4VAeyhXD1U
Hungry Diesel have it in their 'secret handshake' store. Same price.
You'll need an 8mm hex bit/Allen wrench to tighten in the new nipple.I also used Loctite 2442 on the upper threads so it won't unscrew next time I spin off the fuel filter.
Case have it (see above post)for 1/2 price if you are fortunate enough to live in a rural area.
monoblock
Postby CumminsPower59 » Tue May 27, 2014 7:21 pm
If it wasn't leaking....why are you pulling it off :scratch:
Leaving it on is the cheapest option :mrgreen:
Postby DodgeFreak » Tue May 27, 2014 7:26 pm
how much was it at case?
Postby DodgeFreak » Tue May 27, 2014 7:42 pm
11.95 from case.....according to the website....let me see if I would have to pay freight to get one in. If not, it'd be around 12.84 with tax and another 6ish to ship. which is cheaper than genos by a little bit. Not sure how much it cost to get one shipped to you from genos but for me it was another 6-7 bucks and was going to be 26ish bucks. not sure how much you're looking to save I guess.
