monoblock wrote:A loop is usually better because it preserves the designed circulation system.
Some vehicles (ours?)are designed to continuously circulate through the heater core as part of the cylinder head cooling circuit.Your heater control may only operate air-flow flaps,not coolant valves.If you plug the old heater supply/return nipples you block circulation around the cylinder head.
Hopefully someone can confirm if ours have this design or not.
