Fluidampr
Fluidampr
Postby Remps » Mon Feb 16, 2015 9:37 am
Any reason a 2nd gen fluidampr won't work on a 1990 1st gen motor? I would like to retain the 2nd gen crank sensor on the 1990. The motor from my D250 is going in my 2nd gen in a couple months.
Re: Fluidampr
Postby RCCUMMINS89 » Mon Feb 16, 2015 11:35 am
They'll work.... I've heard of most running into fan clearance issues and you'll need to re locate or make a new bracket for your cps.
Re: Fluidampr
Postby Remps » Mon Feb 16, 2015 7:34 pm
You mean clearance issues with a 2nd gen damper and a n/ic fan? I will be using all the 2nd gen accessories, although I also have a ic fan I could use. Not sure if there is any difference between those two fans.
Re: Fluidampr
Postby RCCUMMINS89 » Tue Feb 17, 2015 12:00 am
I've never ran one..... I think BC847 does though..... But i think all 1st gen fans have to be spaced out.
Re: Fluidampr
Postby BILTIT » Tue Feb 17, 2015 5:56 pm
I had to space out my fan when i installed it yup.
I think the same damper is used for 1st and 2nd gens, see the link below.
http://www.fluidampr.com/products/perf-diesel/
Derek B.
BILTIT
Re: Fluidampr
Postby Remps » Tue Feb 17, 2015 11:10 pm
Ok, researched the fan spacing, should be no big deal. :grin:
Re: Fluidampr
Postby thrashingcows » Wed Feb 18, 2015 1:05 pm
I have run the same Fluidampr on an 89 motor, and my current 93 motor. When I was running iton my 89 Non-IC motor I had no fan clearance issues. Before I put on the Fluidampr I had to replace the clutch and fan, since the original 89 units were bent and failing...so I swapped to a 2nd Gen clutch and fan. When I installed the new Fluidampr there was about 1/4-3/8" clearance between the fan blades and dampr.
Now when I installed the same unit on my 93 IC motor...all original...I had to relocate the CPS...it came with a bracket relocation kit. And had to add a good 1/4 spacer behind the clutch fan hub to move it out. Even then I still got a few "ting ting" from the fan at higher RPM's. I eventually had to trim back one or two fan blades to make sure it wasn't making contact with the fluidampr.
thrashingcows
Re: Fluidampr
Postby Remps » Wed Feb 18, 2015 3:48 pm
Yup, sounds like I will have to just play it by ear with the fan. I hope my 90 has as much clearance as your 89.
