No Acceleration, Popping exhaust
Postby jmd4993 » Sun Aug 06, 2017 5:34 pm
92 W250, New custom VE pump, Had pump checked by bosch cert shop, deleted fuel heater after fuel leak there, new fuel return and delivery lines and fresh diesel. Still no acceleration or hi rev. Any suggestions. thanks
jmd4993
Re: No Acceleration, Popping exhaust
Postby BigPapa » Sun Aug 06, 2017 5:38 pm
Sounds to me like your timing is off.
Scott
BigPapa
Postby jmd4993 » Sun Aug 06, 2017 6:54 pm
that could be it but ive had this pump on and off about 5 times and i purchased the tech manuals straight from cummins and have the chilton/haynes manuals. Ive timed it twice but i could check it again. I don't really want to take the front cover off again. I shot some video but dont now how to post it. my email is jmd4993@gmail.com if you want to email me and ill send the video.
jmd4993
Postby ellis93 » Mon Aug 07, 2017 3:50 am
I've had something similar come in my shop and found the owner had not tightened the gear nut tight enough and had the keyway wallow out and retard the pump enough to cause this same thing. I'm not saying yours is the same but could be timing related. I'd advance the timing with the pump slots as far as it will go and see if that clears it up. If it does the back it off till your satisfied with the overall run/idle sound.
Postby CumminsPower59 » Wed Aug 09, 2017 9:48 am
I've had this happen years ago when I was pretty green at building pumps, I had installed the cam plate 180 degrees off. Pretty easy to do, but it makes a difference.
Postby BC847 » Wed Aug 09, 2017 3:53 pm
Throttle indexing off?
Postby DodgeFreak » Mon Aug 14, 2017 8:52 pm
CumminsPower59 wrote:I've had this happen years ago when I was pretty green at building pumps, I had installed the cam plate 180 degrees off. Pretty easy to do, but it makes a difference.
I've done that also but mine wouldn't run at all.
