I got the Hungry Diesel kit for the lift(transfer) pump upgrade for my 1993 .
http://www.thehungrydiesel.com/Low-Pres ... t-Pump.htmI gladly paid the premium for the kit instead of buying the pieces separately to ensure it would fit and work well.It does not fit, nobody is home at Hungry Diesel when I called earlier and the truck is immobile for the weekend !Just hoping someone on this Forum knows the answer.
First problem:
1. No installation instructions -so it must be real easy?
2.No it ain't !I usually work on Porsche and Jaguar so tight/difficult/weird - I get that.
Larry B sells a stud kit .Now I know why.So after wasting time and busting knuckles trying to wrestle 2 gaskets,a spacer and the pump in place I gave up and went off to buy a local substitute for Larry B's longer studs.
Next suggestion -remove the driver's side wheel & work through the wheel well.Direct line of sight to the pump -very helpful.
3.Wow -almost an hour in Friday afternoon Los Angeles traffic & a couple of bucks for two studs and it is sooooo easy to fit !Come on Eric ,include them in the kit !
4.
Final problem that I need help on :- the pump is not even snugged up on the nuts ,yet the outlet fitting is already hard up against the engine block. There is a large lip on the block that partially overhangs the outlet port on the top of the pump.It is impossible to fit the fuel line to the top of the pump. The offending fitting is in the lower left corner of the photo.The upper fitting is for the incoming fuel line
What to do? Installation Instructions would help here but we've covered that issue.
SO 1st Gen's brightest minds are invited to write the instructions for Eric to cover this kinda basic issue I hope?
The options are :
1.rip out the pump and go back to stock - after wasting many unpleasant hours chasing studs and trying to fit the pump.
2.Grind/hack whatever that lip is until the pump does fit.This will require damage to the truck and multiple fit/try/refit attempts .What is behind that lip anyway?
3. your alternative suggestions.
Not how I had hoped to spend the weekend - so very grateful for any helpful suggestions from the Forum.I really need this truck back on the road.
