rear crankshaft adaptor removal
Postby jethro » Tue Aug 12, 2014 3:50 pm
I have my Geno's Dodge shop manual CD on order but it has not come yet.
My engine had an Allison transmission on it- (93 12 valve)
I received my adaptor plate and flywheel spacer and motor mounts from destroked.
My engine appears to have an adapter plate (and stub shaft attached- its about 6 inche disk) which is bolted to the rear flange of the
crankshaft. I removed the 8 bolts going through the adaptor into the crank flange. I also un-bolted the rear seal housing
including the 4 bolts through the oil pan. The seal housing is loose now. My question is how do I remove the adaptor
plate - the bolts are all out- I don't want to hit it much because it is attached to the crank.....
I cant seem to slide the seal housing past it- feels like the lip of the seal is behind it....
Does this thing take some kind of puller to remove it ? It LOOKS like the destroked flywheel spacer
would take its place.... (?)
Any hints? Will post a pic if I can figure out how to.....
Tim
jethro
Re: rear crankshaft adaptor removal
Postby dazedandconfused » Tue Aug 12, 2014 4:49 pm
Post a pic.
Postby PToombs » Tue Aug 12, 2014 4:56 pm
My guess would be whack it with a hammer, but I'm not looking at it. Maybe hit it gently from one side then the other to see if it comes loose. If the bolts are out it may be just rusted/ stuck on there.
Postby jethro » Wed Aug 13, 2014 10:12 pm
I tried bumping it gently left and right...... but it sounded solid...... don't want to mess up the crank flange.....
like to get a slide hammer on it somehow..... but the only rim I could hook a puller onto is behind the seal housing....
at the outer edge....
I will try a pic- but it appears to be fairly complex....
the geno's cd with the dodge shop manual should arrive tomorrow..... hopefully it will show that part.....
Tim
jethro
Postby dazedandconfused » Thu Aug 14, 2014 6:41 am
The picture thing is easy just follow the directions in my SIG.
Postby jethro » Thu Aug 14, 2014 11:20 pm
Try at a picture of the crankshaft adaper on rear of crank.... used to couple to Allison.....
Hope this works !
Does not show on screen.......
Durring editing.... I can copy the link out and paste it into my address bar and it DOES go to the dropbox page with my pick....
I think the pick is like 34 Kb- so I wouldn't think that is too big..... here is the link.....
https://www.dropbox.com/sc/7arx3li2zz6p ... Bw2nIjmdpa (this is inside the two "IMG" brackets)
https://www.dropbox.com/sc/7arx3li2zz6pmvp/AABZrhsKmyJhAD3Bw2nIjmdpa
is this help any ? (used "URL" instead of "IMG")
jethro
Postby CumminsPower59 » Fri Aug 15, 2014 3:54 am
Just hit it with a hammer from the side, its probably just stuck on...and probably will pop off.
Postby DodgeFreak » Fri Aug 15, 2014 5:28 pm
Do you need the adapter??? Id just weld a flat piece of steel across and use a slide hammer on it. Or get a bigger
Hammer. Or tap a couple of the holes and use a slide hammer.....then you could still use it if you wanted.
Postby PToombs » Fri Aug 15, 2014 5:59 pm
Yup, just smack it! It's stuck to the crank. Your new manual won't show that either, it's not a Dodge thing.
Postby dazedandconfused » Sat Aug 16, 2014 5:36 am
I agree just keep hitting it and it will pop off.
Postby jethro » Sat Aug 16, 2014 9:53 pm
GOT IT !
I decided to try hitting it a little more- thought I could see it move just a little......
about 6 hits- off it came. The adaptor has an ID that just wedges onto the OD of the crank flange.
(I suppose to eliminate any chance of relative movement)
The new space goes on the same way- has the same lip that interference-fits with the rear crank flange !
The rubber seal and gasket looked pretty good - but I have new ones !
I have been studying my engine manual fron Geno's (Bishko CD rom)
Has anyone noticed 2 pages missing ? (p144 and 145)
Thanks for the help !
I have a fuel pump, idler, thermostat, water pump... freeze plugs coming.... repainting block the correct colors....
so I have plenty to do.
jethro
Postby CumminsPower59 » Sun Aug 17, 2014 5:52 am
What year of FSM did you get?
Postby jethro » Sun Aug 17, 2014 6:33 pm
its the 1993 dodge service manual on cd-rom from bishko- bought through Geno's garage.
jethro
