Intake plenum cover
Re: Intake plenum cover
Postby Tsapnin » Wed Mar 26, 2014 7:26 pm
Consider it thickened.
Didn't realize the injection or vac pump was different from non ic to ic. Are there functional differences? I'm looking at this thing like someone scavenged it together from scratch one pick and pull at a time. A real you got peanut butter in my chocolate you got chocolate in my peanut butter situation.
The booster was the first suspect for me too-- but im pretty sure the booster is right. Certainly is one of the deepest ive seen.
With all the nonsense she still runs strong an clean (by diesel standards)... God bless America and god bless cummins.
Tsapnin
Postby cmann250 » Thu Mar 27, 2014 4:08 am
Tsapnin wrote:Didn't realize the injection or vac pump was different from non ic to ic. Are there functional differences?
Most consider the IC vacuum pump to be better since it's cheaper to rebuild and more durable.
Postby DMan1198 » Thu Mar 27, 2014 7:30 am
My truck doesn't have its fan shroud either. It's sitting on a shelf in my shop though
Postby Tsapnin » Fri Mar 28, 2014 10:50 am
Well. Tried getting Carl on the phone the last couple days to no avail. So in my impatience I hunted this:
http://m.ebay.com/itm/350982886857?nav=SEARCH
Figure it will solve my problem--plus they'll tap it for a boost gauge for me and its shiny. Which I guess I like. We'll see how fast it turns black under the hood.
Tsapnin
Postby Tsapnin » Fri Mar 28, 2014 1:50 pm
Ok that link up above is for a 12 valve 96 and up. Guy says it should fit. Looks like it will fit. And the port is where I need it. Anyone see any reason it won't do the job? I took measurements on mine and I'm waiting on confirmation that they match.
Tsapnin
Postby cmann250 » Fri Mar 28, 2014 2:19 pm
As far as I know all factory intercooled 12vs have the same plate, 1st and 2nd gen. That should be what you want since your 1st gen intake horn comes straight out.
You may want a confirmation on that though because I've never had both of them side by side.
Postby PToombs » Fri Mar 28, 2014 5:52 pm
I was pulling the tubes off mine last night and made a few observations,
Your booster is right, my '92 is the same. The opening in the plate should start at the back edge of the 2nd valve cover, and go back from there.
So I would have to say the plate is wrong.
Postby CWT » Thu Apr 10, 2014 2:10 pm
I don't want to step out of line by asking here. But if you want to sell the non I/C plenum Tsapnin I would be interested. Might help off set some cost of getting what you need.
CWT
Postby RumbleFish » Thu Apr 10, 2014 7:07 pm
Am I wrong, or do you just flip the plate around?
Postby DodgeFreak » Thu Apr 10, 2014 7:34 pm
does the non ic have the temp sensors??
Postby CWT » Thu Apr 10, 2014 9:26 pm
RumbleFish I looked at that when I first figured out the difference. I will have to look again but I think there is a reason why it wont I just cant remember right now with out looking at it. Maybe someone can verify that.
CWT
Postby PToombs » Sat Apr 12, 2014 6:17 pm
You can't flip yours because the hole is dead in the middle, won't make a difference.
Postby Tsapnin » Sat Apr 12, 2014 9:07 pm
Just got things buttoned up under the hood. New stainless plenum worked out great. Ill post pictures tomorrow of the stock plate. I could have flipped it around. There are injection line clamp bracket mounting holes that would then be useless and on the wrong side of the plate. I opted for the stainless cause I'm figuring on hotrodding the thing a little and it's rated to some ridiculous psi--plus it's shiny. Only shiny thing under that hood.
Cwt ill send you the plate for 50 bucks. I haven't looked into the private message thing but ill shoot you one if I can figure it out.
Pictures tomorrow for ic and non ic comparison purposes.
Tsapnin
Postby DMan1198 » Sun Apr 13, 2014 6:14 am
That's good to hear. I believe you need 25 posts to do pm's
Postby Tsapnin » Sun Apr 13, 2014 6:14 pm
Well that explains it. My emails tsapnin@gmail
Spam away!
Tsapnin
