VE fuel leak between case and hydraulic head
Postby TWorline » Mon Dec 17, 2007 7:42 pm
Thats about all I'm good for! ;)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby gear jammer 91" » Mon Dec 17, 2007 9:23 pm
I had fuel leaking from the same place, all I did to fix it was tighten up the four allen head bolts holding the hydrolic head on. They weren't actually loose I just gave them an extra 1/4 turn or so and the leak stopped. It's a lot cheaper and easier than replacing or rebuilding. . . for now. :)
01 LB7
gear jammer 91"
Postby dpuckett » Tue Dec 18, 2007 11:29 am
If you turned them a 1/4 turn, I'd think they were loose(r) than needed.
DP
Postby bgilbert » Thu Dec 20, 2007 5:39 pm
When reinstalling the hydraulic head, does one have to draw it up tight with the allen bolts compressing the two plunger return springs? I wasn't sure. Didn't know if I could simply push the head back into the pump case. Since it is a junk pump, I went ahead and pulled them together with the allen bolts.....
Bill Gilbert
bgilbert
Postby gear jammer 91" » Tue Dec 25, 2007 10:01 am
dpuckett wrote:If you turned them a 1/4 turn, I'd think they were loose(r) than needed.
DP
I had just adjusted the timing about a week before this without loosening any of the fuel lines and I think that is what caused the hydrolic head to be slightly loose. :oops:
01 LB7
gear jammer 91"
