by cummins32 » Sun Jul 20, 2014 10:13 pm
Got the injectors fixed, had a few stuck ones, fixed all the boost leaks, I'm hittin 40 psi, it pulls good but I just figured id be running more boost, I'm gonn throw a stock fuel pin in it and bump timing one tooth and see how it runs then.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
