Crap
Re: Crap
Postby RCCUMMINS89 » Mon Apr 07, 2014 7:30 pm
Metal shavings in the new diff.
Re: Crap
Postby ellis93 » Mon Apr 07, 2014 7:34 pm
Dang it,that sucks :?
Re: Crap
Postby RCCUMMINS89 » Mon Apr 07, 2014 8:03 pm
Got to be the pinion bearing..... the only thing not replaced was the carrier bearings and pinion bearings. The carrier bearings looked fine. The clutch pack is a steel pack.... but there aren't any signs of them making that kind of mess.
Re: Crap
Postby opiebennett » Tue Apr 08, 2014 3:54 pm
Bummer. Might be worth looking at the clutch pack anyway, I suspect that a piece of mine came loose and went through the ring and pinion mesh, and removed a few teeth from the ring gear for me, haven't had the chance to confirm yet.
Having the diff out to change pinion bearings, it will be on the bench anyway.
Bryan 'Opie' Bennett
91.5 5.9L with 21mm H1C/A518/NP205 Reg Cab LE Pyro/Boost/Trans Temp/BD Fuel Pin/Some fuel screw/Diamond Eye 4" exhaust/B+M Deep Trans Pan/3rd Gen aluminum wheels
opiebennett
Re: Crap
Postby RCCUMMINS89 » Tue Apr 08, 2014 5:13 pm
Oh yea... that was the first thing we tore apart, we seen nothing wrong with a single clutch.
