S362 and 6x16s = 30psi ??
Re: S362 and 6x16s = 30psi ??
Postby RCCUMMINS89 » Wed Jul 30, 2014 11:07 am
^^^this^^^
Postby cummins32 » Sun Aug 03, 2014 6:51 pm
I threw a s366 on it, with a .85 t3 and a 72mm exhaust wheel, it's building 35 lbs but it's spooling a lot quicker, this cleans up the smoke, but I'll check again for boost leaks and te case pressure with the pump, are there any other ways to check that ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Postby RCCUMMINS89 » Sun Aug 03, 2014 10:53 pm
You're just plain running turbos that are too large for a ve .
Postby Tacoclaw » Mon Aug 04, 2014 2:47 am
My HX52 is larger than that turbo, I made 40+ with 5x14's. You're missing fuel somewhere, mang.
Postby fatty » Mon Aug 04, 2014 5:31 am
I watched a guy run a 13.3 with a 66/74/14 on his '92. Made about 50 psi if I remember right. I agree with Taco here, you're missing fuel.
And what about fuel pressure to the VE? Do you know what you have there?
Postby AHineman » Mon Aug 04, 2014 5:55 am
Could you be blowing through the trans......not loading the motor up enough to be at full boost?
Postby RCCUMMINS89 » Mon Aug 04, 2014 8:07 am
A 66/72/15-16ish is a big turbo. I would agree though that he should be getting more than 35 psi.
Postby cummins32 » Mon Aug 04, 2014 9:02 pm
15 psi, could I be running the case low on fuel and it can't keep up with the injectors ? Also I haven't felt it slipping yet, but it's not a built trans by no means, so it could be that,
cummins32
Postby cummins32 » Mon Aug 04, 2014 9:04 pm
Also I was doing a burnout and it'll be in 3rd gear and the turbo will chuckle almost as if I let off the throttle, but I didn't, sound like I'm running outta fuel ?
cummins32
Postby Sutter1stgen » Fri Aug 29, 2014 9:16 pm
Airdog, 6x16s, ground pin, m&h spacer, pump at stock marks/skipped a tooth, Specrite converter, john deere s300/68 that I put a 66ett wheel and .8 gated t3 housing on. My ksb was flipped on the whole pass.
This would have me at 50 psi crossing the 1/4 mile.
With what your describing your losing fuel, and your probably pushing through the converter a bit. A guy with a non lockup auto can not compare boost and egts to someone who has lockup or a clutch. Just doesn't compare. My egts were 1500 degrees at the end of the track, normal acceleration had me close to 1k.
Hope this helps you understand your own setup.
Eric
Sutter1stgen
Postby cummins32 » Fri Sep 26, 2014 7:16 am
Ya, I bet it does have to do with the converter, I switched to a 66 with a t3, and I'm gettin 40 psi, and it's running really good, I'm gonna loctite the front seal and run 30 psi to it and see if it helps at all, I raced a 6.0 the other night and it's got an sct tuner on it and I launched in 4 hi at roughly 20 psi and I beat him pretty bad.. I have all the parts to p pump my truck but I'm planning in seeing what I can get out of this ve it's really surprised me.
cummins32
