7GPM, oh great, now I'm gonna have to dual feed my aftercooler to get that, well close, 6gpm. I guess I'll have to try this 3gpm pump, do some testing. If I could ever get all my parts.
Seeker, not to sound smart butt, but maybe you are seeing such low intake temps because you aren't making any power?? I suppose at 300rwhp+- there ain't as much heat as at 600rwhp:?:.
As far as intended uses of selected pumps and parts, you should know of anyone that just because it says its for school bus use or RV water tank use doesn't mean it won't work for our applications. We as 1st genners should be thinking outside the box so to speak. I could care less if this part or that part started life on a Ford, Freightliner, or big rig etc. The 5.9 Cummins has been around longer than the marriage of Dodge and Cummins. It's been used in tons of applications. Just cause the parts books says it's not gonna work, doesn't mean it won't work. Now I know you are aware of this from your rig and setup. I'm just speaking for others that are reading and often ask the questions of "will this turbo fit" etc.
Now you guys leave Brian alone, I'm supposed to be the only one bugging him all the time with questions
