hot idle chugging
hot idle chugging
Postby ellis93 » Fri Jun 28, 2013 6:24 pm
Well it happens after I pull up to a stop sign after running for 20 or so min with the AC on,turn off the AC and it goes away. Normal idle is at 1k,with the AC on its about 900ish,when it starts chugging its at 500. What's y'alls thoughts on this? Weak pump? Injectors?
This only happens with the AC on and truck hot
Re: hot idle chugging
Postby RCCUMMINS89 » Fri Jun 28, 2013 6:29 pm
Normal for a higher mileage pump.
Working stuff harder, fuel gets thinner...............h/r doesn't push thin fuel as well.
Postby ellis93 » Fri Jun 28, 2013 6:30 pm
Bummers :o
Reckon its gettin turned down then :lol: been wanting to for awhile anyhow
Postby RCCUMMINS89 » Fri Jun 28, 2013 7:23 pm
Turning it don't won't change anything.......... simply keeps you from lengthening the injection event as far at wot.
Postby ellis93 » Fri Jun 28, 2013 7:48 pm
Won't? Wouldn't it take some of the strain off of the H&R? Seems like that kinda thinking works for other hydrologic items I fool around with
Postby RCCUMMINS89 » Fri Jun 28, 2013 8:33 pm
Yes..........and no
All depends if you drive it harder now than you do when it's turned down.
Postby cougar » Sat Jun 29, 2013 9:07 am
01 2500 "the work truck".
cougar
Postby RCCUMMINS89 » Sat Jun 29, 2013 9:25 am
From what I'm reading..............it is.............but only when it's hot.
Meaning that it is putting more of a strain on it when the fuel is warmer............this is "normal" with a higher mileage pump. Heck, mine does it and it still moves tons of fuel.
The way I fix mine is to turn the idle up............mine won't drop down as far.
Postby ellis93 » Sat Jun 29, 2013 11:52 am
cougar wrote:Sure it's not the AC compressor dragging the engine down?
It is and its new....
This really has always happened with the air on but here lately it's gotten worse.
I don't know what I'm gonna do about it.....probably just idle it up :lol:
Postby mhuppertz » Sat Jun 29, 2013 9:08 pm
Next time it is happening, take a hose to your pump and cool it down. I'll bet it starts idling normally.
mhuppertz
Postby ellis93 » Tue Aug 13, 2013 4:24 pm
mhuppertz wrote:Next time it is happening, take a hose to your pump and cool it down. I'll bet it starts idling normally.
That's what it did :sad:
The stars aligned and I happened to be near a set of AC gauges while it was doing it,pressures were fine.....took the water hose to the pump.....it's the problem :o
Mother........ :yuck:
I need a pump :(
Postby RCCUMMINS89 » Tue Aug 13, 2013 5:45 pm
Yep, it sucks..........I feel mine might be before long.
Postby mhuppertz » Tue Aug 13, 2013 5:54 pm
I need a pump too.
Maybe I should put a temp sensor on the pump and have water spray on it when it reaches the "chug" temp!
mhuppertz
Postby PToombs » Tue Aug 13, 2013 6:03 pm
Why not just add some water to the fuel? Then it will be internally cooled! :lol:
Postby RCCUMMINS89 » Tue Aug 13, 2013 6:05 pm
It's due for a lot of these pumps, I mean.....they are 20 years old. H/R assembly from Bosch runs about 450 (re man - but it's Bosch)
