by TRACTJDS0428 » Sat Jul 13, 2013 7:33 pm
This will be kinda long but in the interest of symptoms i believe i need to give details. I have a 93 with a VE and it has been eating shutoff solenoids for a while. you guys have already told me i need bigger injectors or turn the pump down. i haven't messed with the pump yet and just replaced the solenoid on Monday hoping to just take it easy till i get bigger injectors and not destroy another solenoid. On Tuesday i got behind a slow car going about 40 or so and decided to pass so i laid it down because another vehicle was coming towards us and i had time if the truck did what it normally did. well it lit and i got almost around and it de-fueled. lost everything for about 5 seconds then the fuel came back and i got around but it was close at that point. My question is, has anybody had this problem? If so what did you do to fix it or get around it? at this point id rather go back to a manual shutoff and get the power back. It seems to me that maybe the solenoid isn't strong enough to hold the plunger undo full throttle. Or i have bigger problems. Im fairly skilled so just looking for some ideas and people who know more about VE's and how they work.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
