Running the engine with no lift pump?
Postby Begle1 » Mon Nov 19, 2007 5:46 pm
The IP alone should definitely be able to draw enough fuel to idle along just fine, shouldn't it?
Postby Makaio » Mon Nov 19, 2007 7:10 pm
Begle1,
FWIW, I remember reading on TDR and Pastor Bob wrote something about the VE is designed to push way more than it's designed to pull; hence the need for the lift pump.
Aloha,
Matt
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby Begle1 » Mon Nov 19, 2007 7:31 pm
But if I were to just want to test my engine to make sure that it could idle, it shouldn't have any problems with pulling fuel directly into the injection pump from a gas can should it?
And I also hear stories about bad lift pumps causing performance issues over 50 MPH...
Postby gear jammer 91" » Tue Nov 20, 2007 2:50 pm
I read somewhere that our IP's are capable of siphoning fuel from the tank if a lift pump goes bad, making it hard to diagnose. I would imagine that if the IP is capable of that, then a gravity feed setup would be good enough to allow the truck to idle, but I'm no expert.
01 LB7
gear jammer 91"
Postby ford69557ci » Tue Nov 20, 2007 5:18 pm
when my lp went bad with the larger injectors during a full throttle run it would cut out really bad and if released to idle it would die. For normal driving and idle quality the pump bein out didnt effect anything
ford69557ci
