Flames???
Flames???
Postby hassy21 » Mon Nov 26, 2007 12:43 am
I have just removed my afc and put a 3200 gs in and I took it for a test drive and I jumped on it and left off and it shot a little flame out of the straight pipe out of my hood. Just wondering if that is normal or not?
hassy21
Postby CumminsPride » Mon Nov 26, 2007 8:11 am
I would say YES if you have enough unburnt fuel there.
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby hassy21 » Mon Nov 26, 2007 11:34 am
Ya its right after it blows black smoke and I let off and it shoots a little flame out.
hassy21
Postby c12h26 » Mon Nov 26, 2007 1:57 pm
How does she run with the afc removed,higher boost and are the egt's higher
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby wannadiesel » Mon Nov 26, 2007 4:46 pm
We want video! :popcorn:
Best dyno: 408/844
wannadiesel
diesel guru
Postby ford69557ci » Mon Nov 26, 2007 7:41 pm
when i run my hood stack during night drivin after the boost hits 35 i get a flame till i let off the go pedal
ford69557ci
Postby PToombs » Mon Nov 26, 2007 7:55 pm
sounds like you need to advance your timing! ;-)
Postby ford69557ci » Mon Nov 26, 2007 10:17 pm
its 1/4" towards the head if i move it farther it runs worse and if i move it back it runs worse i can put the flame out if i turn on the w/m
ford69557ci
Postby hassy21 » Tue Nov 27, 2007 12:27 am
mine only shoots the flame out when I let off and I know the stock turbo isnt hittin 35 psi on mine. It runs really good though, a lot more power and black smoke. I cant get on it till about 55mph because my tranny slips real bad. i can hit like 95 now that I did that and my 366 spring!
hassy21
Postby ford69557ci » Tue Nov 27, 2007 5:24 pm
i wish my speedo went faster than 100 cuz it sure is easy to bury that and with the w/m off the flame is really kickin at speeds over 100 but the pyro is around1500 :hs:
ford69557ci
Postby hassy21 » Wed Nov 28, 2007 12:39 am
I can only get it to 95 but donat have as many mods as you
hassy21
Postby nooblet » Wed Nov 28, 2007 1:05 am
Mine pegs at 100 and I get scared :shock:
nooblet
Postby hassy21 » Wed Nov 28, 2007 11:41 am
When my gets that fast its not bad in the straight but when I hit the turn it dont feel very safe
hassy21
Postby GO OVRIT » Wed Nov 28, 2007 2:34 pm
I had the cruise set at 80 for several hours on 95 going to Fla a few weeks back. I don't think I've ever tried for any faster than that....course I don't know what speed the tires on the trailer are rated for. ;)
GO OVRIT
Postby ford69557ci » Wed Nov 28, 2007 5:59 pm
i dont think my geolander m/t's are speed rated either but they havent flown apart yet
ford69557ci
