AFC???
AFC???
Postby hassy21 » Mon Nov 26, 2007 11:39 am
I have just taken the afc out and installed the 3200 gs and I was wondering if the fuel pin, smoke screw, and fuel screw were still in need of adjustment with the afc removed?
hassy21
Postby wannadiesel » Mon Nov 26, 2007 4:46 pm
The only one that will do anything is the main fuel screw.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Mon Nov 26, 2007 7:37 pm
You may have to adjust the idle too. Did you turn the screw around while the cover was off?
Postby hassy21 » Tue Nov 27, 2007 12:22 am
I have the fuel screw adjusted 1 1/2 turns.
I also have adjusted the low idle where I want it and the high idle as well.
hassy21
