60 or 90 lbs valve spring
Postby 92cummins89 » Mon May 05, 2014 8:53 pm
Debating if I should go with 60 or 90 valve springs
Have an he 351 cw and 4 inch diamond eye
Plan to p pump it eventually goal is around 400 to 500 rwhp
92cummins89
Re: 60 or 90 lbs valve spring
Postby RCCUMMINS89 » Mon May 05, 2014 9:08 pm
What cam do you plan to run?
Postby 92cummins89 » Mon May 05, 2014 9:16 pm
Tbh haven't gotten tht far was looking at the ones one the hungry diesel
92cummins89
Postby RCCUMMINS89 » Tue May 06, 2014 11:18 am
60# over stock will do everything a ve will need.... unless one is going to run a 188/220 (or so) cam and then run high boost pressures (55-60+). At that point I would start looking at the ones Hamilton recommends.
The larger the cam, the higher the boost pressures, the higher the rpm... the stronger the springs need to be.
Postby 92cummins89 » Tue May 06, 2014 6:50 pm
Question is would it hurt anything to get 90's over 60's tho just to already have it done and not having to buy them twice if u know wat I mean
92cummins89
Postby RCCUMMINS89 » Tue May 06, 2014 8:21 pm
Which "90s" are you looking at?
Postby BILTIT » Wed May 07, 2014 7:33 am
This is a good question, i have a set of new 60's but with the twin setup i am looking at doing i assume 90's would be a better option. Whats your thoughts eric?
Derek B.
BILTIT
Postby RCCUMMINS89 » Wed May 07, 2014 9:01 am
I may be stupid (or ignorant) for not knowing this..... but who is actually making a 90# over stock valve spring for a 12 valve? I can't seem to find any.
Postby DodgeFreak » Wed May 07, 2014 9:47 am
only ones i've ever found was the 60 and 150
Postby DodgeFreak » Wed May 07, 2014 9:50 am
when I was looking at valve springs for my cousins 12valve Jason?? at cpp told me their 150# springs would be fine for his stock cam and that it wouldn't "wear it out" faster. my cousin never did get them so I have no idea if they are a good spring.
Jamie? Maybe....I'm horrible with names lol
Postby 92cummins89 » Wed May 07, 2014 12:31 pm
Saw it on the hungry diesel
92cummins89
Postby BILTIT » Wed May 07, 2014 12:38 pm
RCCUMMINS89 wrote:I may be stupid (or ignorant) for not knowing this..... but who is actually making a 90# over stock valve spring for a 12 valve? I can't seem to find any.
"Dynomite Diesel 90# Valve Springs set of 12 - HDVS-12"
http://www.thehungrydiesel.com/Dynomite ... DVS-12.htm
Derek B.
BILTIT
Postby Tacoclaw » Wed May 07, 2014 1:08 pm
I ran 60# springs with my 188/220 and twins, didn't have anything catastrophic happen. I did have a fresh Cummins head put on and had the guy sink the valves in a little bit while he was porting it to help with piston clearance.
Postby RCCUMMINS89 » Wed May 07, 2014 3:04 pm
Those aren't 90# over stock springs, The 60# over stock springs are actually stronger springs.
My apologies on mis understanding the op.... I was thinking you were referring to 60 or 90 over stock.
Postby BILTIT » Wed May 07, 2014 5:14 pm
Interesting, i didnt realize they were categorized in different ways. Makes me wonder what springs i have now.
Derek B.
BILTIT
