Clutch line help
Clutch line help
Postby 92cummins89 » Fri May 30, 2014 10:28 am
Bent the rod on my peddle to the clutch boost
Not really sure wat it's called or would call it
Have a pic of it but it's the piece the clutch rod pushes against to engage the clutch has a spring on the bottom end of it and I can't figure out how to put it back in
Like I said idk wat it's call
92cummins89
Re: Clutch line help
Postby Tacoclaw » Fri May 30, 2014 1:17 pm
Same deal as what you had going on here?
viewtopic.php?f=2&t=15847&start=15
Postby 92cummins89 » Fri May 30, 2014 1:38 pm
Well it's wat the rod from the peddle pushes thts in the line I can't load a pic I only get days here an there to work on it
So all I do is sit an think bout it on location
I tried to force it back in an can't get it in there
92cummins89
Postby 92cummins89 » Fri May 30, 2014 1:42 pm
92cummins89
Postby Tacoclaw » Fri May 30, 2014 3:58 pm
So it's the piston inside the master cylinder? There's a bunch of pics, measurements, and descriptions in the link I posted in your other thread.
Postby 92cummins89 » Sat May 31, 2014 7:34 pm
I believe so
I got the other part done it won't let me upload the pic of wat I'm talkin bout
92cummins89
Postby Tacoclaw » Sat May 31, 2014 8:20 pm
You'll have to get a pic up somehow, this isn't mKing much sense. :?
Postby 92cummins89 » Sat May 31, 2014 8:34 pm
Ok the rod I talked bout in the other forum is connected to a piece in the line
Any tips on how to upload a pic from iPad or I phone
92cummins89
Postby 92cummins89 » Sat May 31, 2014 9:15 pm
92cummins89
Postby dazedandconfused » Sun Jun 01, 2014 4:57 am
Isn't that the guts out of the slave master cylinder?
Postby Tacoclaw » Sun Jun 01, 2014 11:54 am
Sooooo, you've figured out the rod linkage, you just can't get the piston back into the master cylinder?
Postby 92cummins89 » Sun Jun 01, 2014 4:27 pm
Yea I can't get this piece back in for sthi didn't lnow if u just force it in or wat
An no still haven't figured out the linkage for the rod tht connects to the piece tht holds the throw out bearing cant b no more than 5 inches
92cummins89
Postby 92cummins89 » Mon Jun 02, 2014 8:35 pm
Any ideas?
92cummins89
Postby Tacoclaw » Tue Jun 03, 2014 2:53 am
On the piston, just use a tiny screwdriver or pick to work the seal lip back in. Start it at an angle to seat one side, then just squish it into the bore as you slowly level it out. Obviously you don't want to tear the seal whatsoever, so if it doesn't work the first time pull it out and start over. Just make sure the seal lid doesn't get boogered or flipped over. If it came out it can go back in.
No clue on the slave rod, I know it has a little rubber/plastic nipple over the end that sits in the clutch fork. And it's probably hardened somewhat to prevent bending. I'd pull mine apart to measure, but we're moving hay. If I get a chance I'll take pics and measurements.
Postby 92cummins89 » Tue Jun 03, 2014 3:02 am
So u it's a special rod then ?
Might just go to mopar and get it
92cummins89
