Just another You tube clip Ve pump being machined
Postby roxxx » Fri Dec 07, 2007 8:55 am
http://www.youtube.com/watch?v=b_kVseGmVmI
Just another You tube clip Ve pump being machined Kinda cool to see
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby cummins king » Fri Dec 07, 2007 3:21 pm
what exacly are they doing making a new pump or doing a preformance mod
93 4X4 auto
cummins king
Postby ford69557ci » Fri Dec 07, 2007 5:01 pm
most people take the pump apart before doin any machine work. and what are they doin???
ford69557ci
Postby Underpsi » Fri Dec 07, 2007 5:39 pm
i think they were machining the shaft for a different size nut or something
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby PToombs » Fri Dec 07, 2007 5:54 pm
I read the description, he stripped the threads, turning it from a M14 to a M10 thread. ;-)
