H. Balancer position I did something stupid Please Help
Postby Collers9640 » Tue Jan 17, 2017 6:02 pm
I took off my balancer and timing cover and fan to paint them. Well upon installing I realize that my dumbass didn't mark the balancer position very well and now it's gone. I also did a valve lash adjustment so I do know where tdc is.
My question is this, is there a mark or something on the balancer showing where tdc is or a mark that shows how it goes back on the crank?
Collers9640
Re: H. Balancer position I did something stupid Please Help
Postby ellis93 » Tue Jan 17, 2017 7:16 pm
Far as I know....it doesn't matter. You find tdc with the timing pin in the back of the timing case under the injection pump. You can mark the balancer from there wherever you want to indicate the same thing.
Postby Collers9640 » Mon Jan 23, 2017 1:05 pm
Yes but what im saying is I painting over the mark I had made on the balancer and don't know the position it was at before I took it off
Collers9640
Postby dazedandconfused » Mon Jan 23, 2017 2:31 pm
It doesn't matter how they go back on from what I've been told by the local Cummins dealer
Postby BigPapa » Mon Jan 23, 2017 4:36 pm
Ellis and Andy are correct. Damper position is not important. Find TDC again and mark it any way you want.
Scott
1998.5 QCSB RWD - has '95 12V from my totaled '95, Goerend 47RE, HE351CW, DDIII injectors, 181 DV's, #10 plate, tranny temp, boost, & pyro gauges
1992 D250 ECLB Auto - dyno'd 308/630, PDR pump & POD injectors, 16cm2 E/H, BDP built A518 w/dual coolers, D70 w/LS, EGR disc brakes, dual tranny temp A-pillar, boost, pyro, and tach dash pod
1993 D150 RCSB - Building a DD/Racer Toy
BigPapa
Postby Collers9640 » Wed Jan 25, 2017 2:22 pm
Got it thanks for the help
Collers9640
