dose this guy know what hes talking about?
Postby dodgeracerss » Thu Jan 18, 2007 5:46 am
hey guys i was talking to one of the haulers i work with and this guy told him if he adds a gallon of gas to every 30 gallons of diesel that it wont freeze is that true i was always told not to put gas in it. i just woundering
dodgeracerss
Postby KTA » Thu Jan 18, 2007 6:21 am
You are supposed to use Kerosene, not gas.
Postby Begle1 » Thu Jan 18, 2007 6:40 am
KTA wrote:You are supposed to use Kerosene, not gas.
Nonetheless, I'm pretty sure that gasoline would keep it from freezing. And you wouldn't have to use as much as kerosene.
Do it if you're stuck in the arctic to keep from gelling, but otherwise, no...
Postby dodgeracerss » Thu Jan 18, 2007 5:31 pm
the old man said thats what he dose but i didnt think so it gets -20 where he hauls
dodgeracerss
Postby BEARKILLER » Thu Jan 18, 2007 9:18 pm
Old time truckers used to add some gas to there tanks in sub-zero temperatures.
I grew up in the only truck-accessable, road-fuel selling, filling station in three counties.
We kept a five-gallon can for carrying gasoline around back to the truck pump, so that the truck didn't have to relocate to the gas pumps in front just to get a squirt of gas.
BEARKILLER
Postby smoky beast » Sun Jan 21, 2007 7:31 pm
I let somebody borrow truck one time and they topped off my tank with 7 gallons of gas :evil: , do you think this hurt anything?
1991 D250,non-intercooled,reg cab,5 speed,3:55, flatbed,fuel screw and starwheel maxed,PDR fuel pin, 3200 gov spring,ASA intake w/AFE filter,HTT stage III, 16cm housing,3" straight pipe w/6" tip,AutoMeter EGT+Boost, Mopar RPM guages
smoky beast
Postby MUDDY » Mon Jan 22, 2007 7:50 am
id never ever put gas in my tank. hurts lubrication of the pump. if ya are worried use an additive that has an anti gelling agent in it. 2 stroke also with help with anti gelling and also helps lubrication. 7.39 per galllon of supertech at walmart in the sporting goods section
also read my post at www.idahobombersforum.com and see thaty we are getting a 55 gal drum of fuel additive to split up. its amalgamated TDR blend and this stuff has it all including anti gel. if ya want in on the next drum speak up on that thread.
97 D-3500 flatbed dually 385/837
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
http://www.idahoturbodiesels.com
MUDDY
Postby dpuckett » Mon Jan 22, 2007 8:16 am
smokybeast- 7 gallons in a 30gal tank sure wont help anything. I'd either drain it out or add about 2 jugs of Power Service, et al.
Then dont lend your pickup to anyone that unobservant.
Daniel
Postby JLeonard » Mon Jan 22, 2007 9:23 am
I wouldn't put gas in mine either...BUT
The old VW I had which used a VE pump by the way, said to use gas with the diesel in cold weather...I recall it was either 3 or 5 gallons per 15 gallon tankfull.
So small amounts of gas won't hurt anything.
Jay
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
