Injection Pump Diagrams
Postby oldestof11 » Sat May 05, 2007 7:52 am
I am looking for diagrams for our injection pump, the VE. The reasoning is this. I have the mechanical know-how and the equipment to maybe mod one of these. I was a (actually still am, just only when the demand excedes the workers) machinist. I can get everything down to a 1/1,000th of an inch :twisted: I can read pictures :lol: I prefer on-line pics as the easy access is great!Thanks for any info you guys might have!
Postby swank » Sat May 05, 2007 8:18 am
what's your email?
truck
swank
Postby KTA » Sat May 05, 2007 10:19 am
Is that .001" tolerance or .000001"?
Postby oldestof11 » Sat May 05, 2007 5:13 pm
.001 but we can, if we try real hard, get it down to 0.0001. The main thing is the comparator. We have the equipment to grind, lathe, broach, mill, drill, you get the picture. I am NOT gonna try the 14mm pump or anything that requires more the 0.001. I know about high pressures. I have seen pics of water cutting 1" steel :!: I dont wanna get myself or other guys hurt because of my fiddling. If you suggest not to, then I won't but I wanna take a look at it.
Swank, it should be in my profile now. I just enabled the email thingy.
Postby 2001shrtbedcummins » Sat May 05, 2007 9:08 pm
http://www.dodgeram.org/tech/dsl/more_p ... wer_ve.htm here's a guide to turning one up. But not sure thats what you want.
91 D250 smoke screw turned a little... trying to figure out how to get my big @$$ hands in there and crank up the fuel screw a hair.
2001shrtbedcummins
Postby KTA » Sun May 06, 2007 12:37 pm
the .0001 is the kind of tolerances the pump requires for fit. you can actually hold the plunger in your hand and the heat from it will make it no longer fit the head. :shock: short of making heads or canplates there arent any real mods to be made inside the injection pump.
Postby oldestof11 » Sun May 06, 2007 1:48 pm
Welllll.....Could I do that? Making heads might be a nice challenge for me. I always look for a challenge :twisted:
Postby oldestof11 » Sun May 06, 2007 1:58 pm
Thanks Swank.
Postby swank » Sun May 06, 2007 2:55 pm
no problem
truck
swank
New
Postby A_port93 » Mon May 28, 2007 12:05 am
Im new to this site but find it a little more down to business than dtr and i like it. I was wondering if anybody knows where i can get a good manual from bosch or if there is one available online I would appreciate the tip.
Austin
93 w250 getrag 220k 60/12wg over an ht3b/26 and ddp sticks, south bend ofe
A_port93
