Is the HX35 worth it???
Postby charger 69 » Sun Jun 03, 2007 1:00 pm
90% of what my truck does is tow the 10K plus GN and if the wife has her way we will have a 5th wheel camper sometime this year. What I need is top end power but i don't want to smoke more than nessary. I was looking through PDR and they have the HX35 which they say is good to 350 HP. and I don't see this truck ever doing more than that. Spool up isn't an issue HP. is. I also am thinking of getting 190 injectors and possibily a water/meth setup. IS THE HX35 worth the money for my application or will the stock turbo do the job as well?? Thanks. :?
92 White D350 132K,mi. fuel screw in 3,5 turns automatic with a Hughes converter and 26K add on cooler.Aluminum wheels,second fuel tank,gooseneck hitch,air bags tach.and gages,
charger 69
Postby dpuckett » Sun Jun 03, 2007 1:03 pm
The PDR HX35 will lower your EGTs and allow more power than the stock HX35. I am considering that same turbo at this time, as my "reman" turbo I bought appears to have more slack in it this week than last, and it screeches at higher boost levels, but is not consistent. More on that another time.
I put one on my nonIC 91, and it cooled things off considerably, and increased spoolup, just like they claim.
If I had the money, I would get the HX40 or S300 (do it once, and be done, like KTA says), but the $350 difference will buy a lot of fuel.
Daniel
Postby charger 69 » Sun Jun 03, 2007 1:37 pm
Its my understanding that the HX40 wont live up to the expectation unless you have the power to make use of it as I was looking at it also but I agree with you in the "pay for it once" line of thought.
charger 69
Postby crossy » Sat Jun 09, 2007 10:59 am
I certainly am not the one to answer whether it is worth the money, but I think it is all you will need for your final plan so 'buying it once' will be exactly what you are doing if you get the modified HX35. It fits into your modest goals.
I looked at a lot of Signatures and even Pm'd some guys who did not list their mods, about their mods to get up to the HP/TQ levels they were boasting.
what i found was several guys claiming decent HP levels , with no EGT issues, and they were using STOCK hx35's so a modded one should be great??
I bought a bone stock one with 12CM and once i get all my other ducks in a row I'll already have the right plumbing in place to buy a modded one.
crossy
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Postby Cowboy_Customs » Sat Jun 09, 2007 1:06 pm
For what your doing, it'll be a great turbo. I used the HX-35's counterpart, a WH1C for a while before the accident, and loved it. The spool up of the 12cm housing was a nice change over my stock 18cm. Plus the WH1C/HX-35 offered the MWE slot to eliminate bark, and a larger compressor to offer more air for my fueling. I think you'll be very pleased.
Now you mentioned top end power, have you advanced the timing, and added the 3200 GSK?
Sorry I havent been round here too much really. just a glance now and then.
Lost, but not forgotten. '93 Dodge D-350 regular cab 2x6, 5-speed, Phantom Pyro, LED guages, Polished valve covers, 366 spring, 4 inch Rip DP, to 6 inch stacks, lots 'o lights
http://community.webshots.com/user/Cowboy_Customs
Cowboy_Customs
Postby charger 69 » Mon Jun 11, 2007 2:52 pm
Yep the 3200 spring is the next order of business along with advancing the pump whick brings me to a question. Does advancing the pump help cool the engine temperature as that is a problem with this truck??
charger 69
Postby Cowboy_Customs » Mon Jun 11, 2007 3:53 pm
Advancing the pump helps with fuel mileage, and EGT's. It does take some power away from the bottom end, but moves it toward the top end of the RPM band.
Cowboy_Customs
Postby dpuckett » Tue Jun 12, 2007 9:03 pm
In theory, you are right. BUT, depending on where "stock" is, you may gain bottom end, too, by advancing a slight bit (to 1.4-1.5mm). There is a point where one starts to lose bottom end, though.
What kind of EGT issues are you having? What RPM? The turbo is one of many players in that game. Timing and injector condition will also affect EGT.
Daniel
Postby Paccool » Wed Jun 13, 2007 9:52 am
The PDR35 is a good choice. I ran one for several years before the twins and was towing a 7000# trailer. Had about 36 pounds of boost. What housing are you going to run? I had the non wastegated 16 and that was a good housing. I'm now running that same turbo as the top one of the twins with a 12 wastegated housing.
I think the 40 might be a little laggy for towing but can't sa for sure cause I have not towed with one.
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby seeker1056 » Wed Jun 13, 2007 10:20 am
hmmm, in my engine manual, 1.4 is stock timing.
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby KTA » Wed Jun 13, 2007 11:04 am
I tow with a HX40/16cm and 300rwhp. I can run full throttle most of the time with the 40 and it peaks at about 1300egt's. With the stock H1C/18 it would run 1500 easy, so the 40 was worth about 200deg egt reduction.
Postby charger 69 » Wed Jun 13, 2007 11:46 am
KTA wrote:I tow with a HX40/16cm and 300rwhp. I can run full throttle most of the time with the 40 and it peaks at about 1300egt's. With the stock H1C/18 it would run 1500 easy, so the 40 was worth about 200deg egt reduction.
Thats what I am looking for,to be able to run wide open and have the power and not bake the engine doing it. Someone on another site said comming up an on ramp empty is one thing but with a heavy load is all together different and thats what I am looking at. I need the grunt on the top end.
KTA what injectors do you have?? I thought we could only get 190s and Pods. I am thinking a water /meth system and possibly larger injectors if I can keep the temps down
dpuckett - Egts at 2500 RPM will rocket right past 1500* when its working hard unless I drop it into second gear. If I do pull in overdrive everything gets hot quickly so I need the 3200 spring first.
charger 69
Postby KTA » Wed Jun 13, 2007 1:06 pm
That truck has 370tips on 1st gen bodies. They were cheap and are a decent sized injector without going to POD's. They do haze bad because of the wrong spray pattern but I don't care. Truck has stock air filter and full 4" muffled exhaust. It pulls the pulling truck gross weight is 23000lbs usually.
Postby charger 69 » Wed Jun 13, 2007 1:53 pm
I think between truck ,trailer, and load I am about 20-22K so if you can keep your combo under 1300* I shouldn't have a problem with 190s and water/meth and an HX40 plus it will need a 4" down pipe anyway. In my case I'd like to keep the smoke to a minimum so I don't upset somebody in our "politicly correct" world.
Do you have any knowlege of the DDP injectors from Piers?/ They seem a step up from 190s but look a bit pricy.
charger 69
Postby dpuckett » Tue Jun 19, 2007 5:36 pm
People who have run the DDP3s and 4s like them, but airflow is a must. Beyond that, I cant tell you much.
seeker1056- If you look on your engine plate (provided it is still on the engine), the timing for intercooled engines is 1.25mm; nonIC was 1.4. What year is your Cummins manual from?
DP
