turbo lag
turbo lag
Postby 93 dually » Wed Jun 13, 2007 11:19 pm
ive got a htt turbo 16cm exhaust and im getting alot of midrange lag should i run a 14 or a 12cm for a quicker spool :?
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
Postby MikeThomas » Wed Jun 13, 2007 11:34 pm
Hmmm, thats odd, what do you consider midrange? As soon as I hit about 10psi it only takes a split second to reach 34psi. Its that 0-10 psi that is the slowest for me. What is your max boost level?
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby 93 dually » Mon Jun 18, 2007 3:49 am
max boost is 30psi and thats with my foot in the oil pan
93 dually
Postby dpuckett » Tue Jun 19, 2007 5:20 pm
Do you have a tach? What fuel enhancements have you done? Fuelling will have as big of, if not bigger, effect on spooling than turbine housing size. Yes, please define "mid range."
Mine is laggy to about 17-1800RPM, then it really takes off (jump to mid 20s). I have it that way intentionally, to reduce intown fuel usage/ EGT. I can loosen my AFc spring and lower the RPM it comes on.
Daniel
