Postby matthewh » Thu Mar 06, 2014 6:19 pm
PToombs wrote:I won't buy anymore batteries from Carquest. They gas all the time and the battery is all acid on top and the terminals are always corroded. About a week after I bought the set for my 2nd gen I was on TDR and there was a big thread on batteries, quite a few guys said the same thing about their Carquest batteries. I wish I had looked there before I bought them. And then 1 was a month out of warranty when it puked and the prorate was 1/2 the cost of a new one. Now I have new set of Dekas in it and it starts great and no mess. 8)
Thanks Pete, I'll have to look at the one in the dually, see if its got any issues starting. Good to know, since I gotta buy 2 group 31's for the M37 project
matthewh
Postby RumbleFish » Thu Mar 06, 2014 6:51 pm
ihredneck wrote:
RumbleFish wrote:I have the 31-5 in my truck. Starts just fine, even if i forget to plug it in and the temp hits subzero. Ill see if I can dig up a 31-6 anywhere next time Im at the O.
O O O O'Reilly,......Auto Parts! ;)
:puker:
Postby DMan1198 » Thu Mar 06, 2014 8:06 pm
My 4th gen is frustrating me. Yesterday and the day before it went into something like a limp mode and I had to reflash. So I loaded my own stuff and it consistently throws all 6 injector circuit open codes when I run on performance, and I really like running on performance
Postby ihredneck » Thu Mar 06, 2014 9:07 pm
I did some research on where batteries are made and found that NAPA batteries are the same as Dekas and if I recall correctly so are the Super Starts from O'Reillys
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby RumbleFish » Fri Mar 07, 2014 5:23 am
Oreilly batteries are made by east penn, who also makes deka iirc. Unless the part # has a J on the end, which designates Johnson Controls and I would avoid them.
We have a fairly low warranty return rate imo on our super starts. Nothing like all the warranty returns we had at advance. We get tons of walmart, rural king, and advance batteries in as cores. Alot of times they are just barely out of the warranty coverage, and sometimes they are still covered. Generally the napa and interstate batts we get are years past the warranty.
Postby DMan1198 » Fri Mar 07, 2014 6:00 pm
Anybody know if 13mm p pump barrel and plungers are straight Bosch made? I kind of want to try my hand at building the 175 p pump I have
Postby dazedandconfused » Fri Mar 07, 2014 6:06 pm
Speaking of Batteries and such Im still having issues with my Ford. Its not charging at the batteries. I changed alternators with Dads 97 and its still not charging. I can only get 12.2V's at the batteries while its running but I get 14.8V's from the same alternator on Dads. Does anyone have any ideas?
Postby PToombs » Fri Mar 07, 2014 6:22 pm
Put a new truck under the driver? :twisted:
Need input from you guys, what color should I paint my IC tubes and the pipe between the turbos? Green the color of the truck or black? The drivers side tube is black but has a rust spot I need to deal with, and the other 2 pipes are bare metal right now.
Thanks guys!
Postby cmann250 » Fri Mar 07, 2014 6:34 pm
Why paint anything under the hood? I'm going to paint my welds on my cold pipe and IC tube and that's it.
Hide and watch. I'm serious. :lol:
I vote PCM issues Andy. I don't remember why, but I think the PCM controls charging. Check out Power Stroke Army.
Postby AHineman » Fri Mar 07, 2014 6:41 pm
Pete, you can't go wrong with gloss black and Cummins biege. My intercooler piping is black, and cold pipe is biege.
Postby ellis93 » Fri Mar 07, 2014 6:50 pm
Pete I'd go black but that's me. Sometimes I paint engines orange too tho :lol:
Postby Tacoclaw » Fri Mar 07, 2014 7:02 pm
Detroit Diesel Green, duh. 8)
Postby DMan1198 » Fri Mar 07, 2014 7:26 pm
What about painting it so it looks like fire?
Postby dazedandconfused » Fri Mar 07, 2014 7:47 pm
cmann250 wrote:Why paint anything under the hood? I'm going to paint my welds on my cold pipe and IC tube and that's it.
From what I've read the alternator has a internal regulator. Something about the battery light must come on with the key on though for it to charge.
Postby ellis93 » Fri Mar 07, 2014 7:50 pm
Andy what made it go back to running? I'll look on Mitchell in the morning for you.....message me and remind me.
