Postby Tacoclaw » Fri Mar 21, 2014 6:00 pm
Don't see the need to start a new thread over it, but I've got to know. Any idea what the hell this plug does?
'91, all power harness going into an '89 gasser Ramcharger. No plug like it on the RC and it was waaaay too dark to see it on the other cab when I got home. :(
Postby PToombs » Fri Mar 21, 2014 6:10 pm
That goes to the tail lights I think. Goes out thru the rubber grommet under the steering column.
Postby CumminsPower59 » Fri Mar 21, 2014 6:18 pm
Pete's got it. Looks the same as the one on my 91...
Postby DMan1198 » Fri Mar 21, 2014 6:29 pm
So I think my 4th gens transmission keeps throwing the truck into a limp mode. It'll still make 22psi of boost, but it just isn't the 36 it'll make otherwise. A revmax 850 might come sooner than initially planned
Postby meby » Fri Mar 21, 2014 6:36 pm
Philip wrote:
meby wrote:Phillip: did Jeremy tell you i'm coming down tomorrow?
No he didn't. I'll be out there working on the truck.
Yeh. He said you might be.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby cmann250 » Fri Mar 21, 2014 6:37 pm
I am now a built auto guy. The only other trans I'd have in a pick-up is a 10 speed.
With just direct (no O/D), I can get cooking. O/D will be scary.
Postby Philip » Fri Mar 21, 2014 6:40 pm
cmann250 wrote:With just direct (no O/D), I can get cooking. O/D will be scary.
Well you know the old saying. Hang on and grin. :lol: :lol:
Postby Philip » Fri Mar 21, 2014 6:42 pm
BC847 wrote:Salt-air does a body good. ;)
Yea that why I did a body swap on mine. To much salt air from MI and IN.
Postby Tacoclaw » Fri Mar 21, 2014 7:00 pm
Well, that sucks. Thanks for the info, guys. :grin:
I threw the '92 harness on the engine with the '91 cab harness. Nothing is happening when I hook the battery up, and even less happens when I turn the key. :lol:
I'll sniff around my diagrams and the stuff Ellis has uploaded and see if I've even got a chance of this working. :roll:
Postby fatty » Fri Mar 21, 2014 7:24 pm
DMan1198 wrote: A 48re swap might come sooner than initially planned
There I fixed it for you. :D
Postby Tacoclaw » Fri Mar 21, 2014 7:35 pm
Kind of a long shot, but does anyone have a pin out of the 92-93 bulkhead connector? I've got the pin outs for the 89 and 91 harness, just kinda trying to figure out where the hell my power is going. :?
Postby ellis93 » Fri Mar 21, 2014 8:15 pm
Tacoclaw wrote:Kind of a long shot, but does anyone have a pin out of the 92-93 bulkhead connector? I've got the pin outs for the 89 and 91 harness, just kinda trying to figure out where the hell my power is going. :?
I'll look tomorrow,I'll be at the shop at some point and I'll try and find it......go do something else in the morning :lol:
Postby Philip » Fri Mar 21, 2014 8:34 pm
Postby Tacoclaw » Sat Mar 22, 2014 2:08 am
Awesome, thanks, Philip!! And Ellis. :P
Apparently the only wire that is different is #24. It's the OD indication light on '93's that apparently the older stuff didn't have.
Crap. :?
Postby DMan1198 » Sat Mar 22, 2014 8:41 am
I don't want a 48re in my 4th gen. Some have had issues with surging, and I like the extra gears. If I wreck the 850 then I might switch to a 48
