2022 BS and chat thread
Re: 2022 BS and chat thread
Postby Richie O » Tue Nov 22, 2022 11:26 am
spencerdiesel wrote:Richie did you get the death wobble sorted? When mine had DW a new drag link cured it.
No, still have it. I put a new drag link on last year, still has it. Tightened up the steering box, still has it. I can not see any play in tie rods. I see no cracks in the frame. It may be a combo of slight wear on a few things. Drives me crazy.
Postby spencerdiesel » Mon Dec 12, 2022 3:24 am
Is the bracket holding the steering box crack free?
H1C/18
Muffler delete
spencerdiesel
Postby Richie O » Thu Dec 15, 2022 1:55 pm
As far as I can tell. The poor truck is just worn.
Postby u2slow » Sun Dec 18, 2022 5:05 pm
I reckon your caster is borderline low. Sagged springs, worn bushings, etc. No, there isn't an 'adjustment' per se... but you can replace the shackle with a longer one which tilts the the diff slightly and adds caster.
I built 5" shackles from flat bar and never had DW since. In fact, I've had a sloppy steering box, cracked bracket, and a worn draglink since. Still no death wobble.
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby Richie O » Mon Dec 19, 2022 8:22 am
u2slow wrote:I reckon your caster is borderline low. Sagged springs, worn bushings, etc. No, there isn't an 'adjustment' per se... but you can replace the shackle with a longer one which tilts the the diff slightly and adds caster.
Very well could be. It has a super heavy home built winch bumper / brush guard and original springs. Pretty much flat on the bump stops. It appears to me to need a camber king pin kit as well, the drivers side looks a touch out of spec on camber, yet the king pin is tight. Im the 3rd owner and its been a work truck since new. Getting old, just like me.
