Postby DMan1198 » Mon Mar 24, 2014 6:06 am
I haven't heard of any issues though I haven't exactly looked into it
On another note I suspect the reason my truck was throwing codes was because of my timing maps, but I'm not sure
Postby DodgeFreak » Mon Mar 24, 2014 6:43 am
getting old sucks....I was up till 2am setting up a set of injectors sat night and then my kids woke me up at 7:30am and now I feel like death warmed over..... I remember when I could work 4 days in a row on a couple hours of sleep and be ready for school Monday morning.......
Postby DMan1198 » Mon Mar 24, 2014 11:47 am
You were a lucky one then. I was never really ready for school no matter how much sleep I got. Hence why I slept in class almost every day. At work I don't fall asleep, but I get slower the more tired I am
Postby DMan1198 » Mon Mar 24, 2014 4:49 pm
So h&s hot damn vs the standard stuff is pretty well night and day. No codes and no traction whatsoever on the dry gravel road. I think the codes were actually cause by my screwing with the timing maps. It's either that or trying to command over 3.9 msec of duration for 125mm^3 rather than the stock 150mm^3
Postby PToombs » Mon Mar 24, 2014 5:11 pm
Tom, there is no lift pump on a TDI, the newer ones anyways. The vane pump pulls the fuel from the tank. From what I have heard the pumps are pretty reliable, they are more of an electronic VE than a chronic VP.
Buddy of mine had a hard start issue, the water drain on the filter wasn't sealed good, and was sucking air. You have to pull the filter to access it. :roll:
Postby cmann250 » Mon Mar 24, 2014 5:17 pm
DMan1198 wrote:So h&s hot damn vs the standard stuff is pretty well night and day. No codes and no traction whatsoever on the dry gravel road. I think the codes were actually cause by my screwing with the timing maps. It's either that or trying to command over 3.9 msec of duration for 125mm^3 rather than the stock 150mm^3
Give the '93 the love it deserves and get out of that devil's chariot computer controlled truck :lol:
Postby dazedandconfused » Mon Mar 24, 2014 5:31 pm
I swear your a 80 year old man trapped in a young mans body. :mrgreen: I guess I'll work on getting my RC tank in and swapping fuel systems. I felt the truck pull down on fuel pressure after a hard launch today. It fell on its face shortly after grabbing second.
Postby cmann250 » Mon Mar 24, 2014 5:51 pm
dazedandconfused wrote:I swear your a 80 year old man trapped in a young mans body. :mrgreen:
You're not the first person to tell me that :lol: I'm a straight shooter and I call it how I see it.
Postby oldestof11 » Mon Mar 24, 2014 6:28 pm
txs wrote:we are interested in a 2002 beetle 5 speed, do you need to keep a close eye on lift pump pressure like you do the vp44 trucks?
No lift pump but i recommend putting one on. Amazing how much it helps.
Postby DMan1198 » Mon Mar 24, 2014 6:34 pm
I'm still waiting on steel to do my hotpipe. It's getting to the point of frustration now since I was so excited, and now I'm stuck where I was over 2 weeks ago. I do have stuff to do my fuel system, but I need a large enough container to store half a tank of fuel so I can put my sump in
Postby txs » Mon Mar 24, 2014 7:15 pm
caleb, i'm with you, vehicle electronics are the spawn of satan.
txs
Postby DMan1198 » Mon Mar 24, 2014 7:33 pm
I'm good with the amount of electronics on my 4th gen, but any more and I can't stand it
Postby CumminsPower59 » Mon Mar 24, 2014 7:36 pm
TDi's got lift pumps when the PD (BEW) engines came out in 04...I can hear the one on my 04 soon as the key is turned to "run", makes a squish kind of noise when it it pressurizes the system.
Postby 1STGENFARMBOY » Mon Mar 24, 2014 7:49 pm
The ALH engine is one of the best TDI's made, but keep a close eye on the timing belt, it can sneak up and
bit you for about $1,200 with you doing all the work.
Postby CumminsPower59 » Mon Mar 24, 2014 8:36 pm
I would love to get a tune from Malone on my 04...I guess the PD engines respond really well from just a tune.
