Postby dazedandconfused » Wed Apr 09, 2014 8:04 am
I thought it was kinda funny only because it wasn't my nuts. :lol:
Postby ellis93 » Wed Apr 09, 2014 9:39 am
DMan1198 wrote:Maybe Ellis has his April fools on the ninth
No I thought it was funny.....guess I should have explained thAt it was written as such. Guess I should have expected tender feelings over the subject
Postby DMan1198 » Wed Apr 09, 2014 12:57 pm
I will admit I'm apathetic towards most things, and the quote in Caleb's sig is pretty much my approach to life
Postby cmann250 » Wed Apr 09, 2014 3:58 pm
DMan1198 wrote:...and the quote in Caleb's sig is pretty much my approach to life
You and me both :lol:
I don't know if any of you wrestled, but here's the story. A kid that wasn't very good but had a lot of heart picked bottom and needed one point (an escape) to tie the match and go to over time. Coach Smith asked "Nick, can you get off bottom?" The mandatory answer from the wrestler is "Yes!" and you fight like heck to get out and tie up the match. Well Nick said "No, I don't think so". So he essentially screwed himself out of the match by picking bottom when he could have picked top and scored offensive points. Coach Smith flung his hands in the air and said "Whatever!" when any other coach would have been livid.
Coach passed away my senior year and that quote, along with "It's Saturday!" to describe tournament day, still make me smile.
Postby DodgeFreak » Wed Apr 09, 2014 6:08 pm
serviced the engine on the crew, and while I had it up in the air checked ball joints ect........both upper and lowers on both sides are shot, both wheel bearings were loose....soooo.....looks like I'll be doing ball joints before I drive it to much....
Postby DMan1198 » Wed Apr 09, 2014 6:26 pm
I just found out the 81 Volkswagen rabbit in my yard has a ve. There's no ksb, or afc (though that ones understandable because it's non turbo) I think I'll do some more research on it
Postby Tacoclaw » Wed Apr 09, 2014 6:33 pm
Cropped up a pic of the Dodge, gotta host it somewhere so I can save it to my phone.
Sorry, guys. :P
Postby DMan1198 » Wed Apr 09, 2014 7:19 pm
Well it is a cool truck so I think I can tolerate it
Postby Bob L » Wed Apr 09, 2014 8:01 pm
DodgeFreak wrote:serviced the engine on the crew, and while I had it up in the air checked ball joints ect........both upper and lowers on both sides are shot, both wheel bearings were loose....soooo.....looks like I'll be doing ball joints before I drive it to much....
How do you check ball joints ?. I'm guessing by applying leverage somewhere , but where ? Is some movement acceptable, or the tighter the better ?.
Do better shocks help make the ball joints last longer ?.
I 'm sure regular lubrication plays a big factor.
I have never checked mine, I think it's time. ;)
Thanks,
Bob
Bob L
NRA Life Member 1974
'92.5 D250 LE EXT.CAB...Getrag...All Original...No Rust...
Purchased new in late Oct.'92---128K Mi. Still Like New.
Bob L
Postby DodgeFreak » Thu Apr 10, 2014 5:13 am
use a jack under the lower control arm to keep the suspension compressed then I grab the top and bottom of the wheel and try to move the tire in and out. I always leave them alone if I have to work pretty good to get movement. It gets tricky if your wheel bearings are loose to figure out if its the ball joints or wheel bearings.
Postby Bob L » Thu Apr 10, 2014 6:50 am
DodgeFreak wrote:use a jack under the lower control arm to keep the suspension compressed then I grab the top and bottom of the wheel and try to move the tire in and out. I always leave them alone if I have to work pretty good to get movement. It gets tricky if your wheel bearings are loose to figure out if its the ball joints or wheel bearings.
Thank You ! Much appreciated.
Thanks for your explanation. I will give it a try.
Bob L
Bob L
Postby skilletky » Thu Apr 10, 2014 1:50 pm
i drove my 1stgen today. 1st time in a long while. almost makes me not want to sell it.
skilletky
Postby DMan1198 » Thu Apr 10, 2014 2:03 pm
Why would you ever want to sell a first gen?
Postby dazedandconfused » Thu Apr 10, 2014 3:18 pm
Because I contaminated him by selling him my 01. Lol
Postby DodgeFreak » Thu Apr 10, 2014 7:06 pm
honestly, I would rather own a 3rd gen than a 1st if I could afford it. I like the ride a whole lot better.....even if I sold all three of mine I wouldn't be able to touch a 3rd gen.
