Postby DodgeFreak » Fri May 02, 2014 5:13 am
Hows the job treating you Ike??
Postby CumminsPower59 » Fri May 02, 2014 12:18 pm
Haven't started yet :?
My supervisor wanted to keep me around for a month so he could request and fill my mechanic spot. I start at the plant on Monday the 19th.
Postby dazedandconfused » Fri May 02, 2014 1:47 pm
Well that sucks.
Postby matthewh » Fri May 02, 2014 9:28 pm
So just got home from a day trip roaming lower Michigan scooping up parts for my various projects. Other than the small pond I found this am on the pass floor I addressed in another post, had a weird issue that cropped up again. While cruising down the road, cruise set at 60, engine just shut off. Its done it before, not sure why. I tried the accelerator pedal, still set down like cruise was on, I pushed the clutch in, engine came back and away we went.
Thinking the vss connection is loose or bad connection. Its random, not constant reason why, just doesn't it now and them.
Was happy to see 20.5mpg 8)
matthewh
Postby Philip » Sat May 03, 2014 4:54 am
A bad VSS connection will not kill the engine. A bad connection at the FSS will. Replace the wire terminal on the FSS wire.
Postby matthewh » Sat May 03, 2014 5:13 am
Philip wrote:A bad VSS connection will not kill the engine. A bad connection at the FSS will. Replace the wire terminal on the FSS wire.
Oops, meant FSS connection, guess even proof reading doesn't help :roll:
matthewh
Postby cmann250 » Sat May 03, 2014 10:03 am
I formally accepted my job at Cat yesterday. I'll miss the side dressing, spraying, and hay work that is farming in the summer, but Cat pays better and it could turn into a fulltime job. It's still only 10 minutes from the house. Can't complain about that 8)
Postby Philip » Sat May 03, 2014 10:12 am
cmann250 wrote:I formally accepted my job at Cat yesterday. I'll miss the side dressing, spraying, and hay work that is farming in the summer, but Cat pays better and it could turn into a fulltime job. It's still only 10 minutes from the house. Can't complain about that 8)
Are they going to let your cummins in the parking lot?? :lol:
Postby cmann250 » Sat May 03, 2014 10:22 am
Philip wrote:Are they going to let your cummins in the parking lot?? :lol:
I've already checked. I won't be the only CTD in the employee lot. :lol:
Postby ellis93 » Sat May 03, 2014 10:23 am
Good deal Caleb,congratulations!
Your probably gonna be given schit about your cummins tho :lol:
Postby cmann250 » Sat May 03, 2014 11:20 am
Thanks Ellis.
Fortunately, you all have prepared me for any and all hassling that could occur, given my affection for Navistar powered Fords :lol:
Postby DMan1198 » Sat May 03, 2014 11:36 am
Fords are terrible. That sounds like it'll be a good job though Caleb. From what I've heard people that work at cat end up going cat crazy.
On another note jaegers gauges came in yesterday after nearly 2 weeks in transit
Postby cmann250 » Sat May 03, 2014 2:58 pm
DMan1198 wrote:That sounds like it'll be a good job though Caleb. From what I've heard people that work at cat end up going cqg crazy.
I don't know what all that means. I pretty much refuse to do any mechanic work in a professional context unless it's short term, a jump in pay, and on the way up the ladder. Outside of work, I'm the designated mechanic for a large pool of friends and family. There's no way I'd wrench for 8 hours only to come home and do the same for a few more hours :lol:
Postby DMan1198 » Sat May 03, 2014 4:00 pm
I fixed it. I meant to say cat crazy, but wasn't looking at my phone while I was typing.
And I put the pillar with gauges (though they're not connected to anything) in jaeger. It's much easier to do than the partial pods our first gens have
Postby Philip » Sat May 03, 2014 6:10 pm
Hea BC the site is still loading very slowly.
