Postby RCCUMMINS89 » Sun May 25, 2014 7:59 pm
And maybe they were? I am simply going off from what Sutter mentioned to me. (but again, maybe I'm mistaken)
Postby DMan1198 » Mon May 26, 2014 7:01 am
I could do with a stiffer afc spring. Do you know if there's different springs for the p pumps as well?
Postby RCCUMMINS89 » Mon May 26, 2014 9:54 am
I already am selling a spring that is about twice as strong as stock for the ve pumps... this one is just even that much stronger (about 4x stronger than stock).
There are stronger springs for the p pumps as well.... I'd have to look and see who already makes kits. Otherwise, send me specs on the stock spring and what you want it to be and I'll make something happen.
Postby cmann250 » Mon May 26, 2014 10:06 am
Dar, you'd be pleased to know this proud International owner is using some 2 bangers to get hay done today. I'm running a gas narrow front 630 and a diesel pony start wide front 720.
Oh that 20 series sheet metal 8)
Postby Tacoclaw » Mon May 26, 2014 11:44 am
Big respect and gratitude to the vets, both here and gone. :salut:
Time for me to get to fishin'.
Postby ellis93 » Mon May 26, 2014 7:14 pm
Owned a ford for less than a week and have dropped a smooth grand :shock:
I just don't know how ford guys do it :lol:
Postby dazedandconfused » Mon May 26, 2014 8:24 pm
What did you find wrong with it?
Postby ellis93 » Tue May 27, 2014 3:44 am
Sticking injector(s),plastic intercooler tube has holes (totally stupid idea),axle shaft u joint on passenger side is falling out,square tires, and I ain't done with looking it over.
I bought rev-x to put in the oil to help out the injector that's sticking,I'm hoping that's all that's going on. It really should be because once it runs for a solid minute it clears up and won't miss again till it's cooled off. The plastic cooler tube has holes worn in it from the air box wallowing around on top of it because some genius broke the battery box up. That must be easy to do,neither side is in the truck and they are expensive has hell. The driver side box is 58$ and the passenger side is 141$ from ford,I'm looking for used ones.
There's a pretty good bit of wrong with this truck and it's sad to say most of its is pure stupidity on previous owners part. :|
Postby Tacoclaw » Tue May 27, 2014 7:08 am
ellis93 wrote:There's a pretty good bit of wrong with this truck and it's sad to say most of its is pure stupidity on previous owners part. :|
Well, what do you expect from him? He did buy a Ford... :mrgreen:
Postby 1STGENFARMBOY » Tue May 27, 2014 8:31 am
I took some stacks in on trade for some horse boarding, stuck them on yesterday, thought I would post
a pic for Pete.....just so he knows he ain't the only flat billed douche around.... :lol: :lol: :lol:
the 6 inch ones sound good though, I can't have them on much in the summer because of the camper, but it only
takes 20 min to swap out to the tail pipe.
and my memorial day shot
Postby BC847 » Tue May 27, 2014 8:58 am
Sharp ride. 8)
I wish my paint was that clean.
Postby dazedandconfused » Tue May 27, 2014 9:32 am
Looks good Dar. I traded an old MTD Zero turn for these yesterday.
Postby DMan1198 » Tue May 27, 2014 3:26 pm
That is a beautiful truck. I wish mine looked that good. Even half as good would be a big improvement.
Eric I think I'll be wanting all the different afc springs so I can experiment. If I got the right p pump it's got 13mm barrels and plungers, and 5k gov springs. The only thing I know for sure is it has full cut delivery valves. I'd have to double check to see if it has bigger delivery valve holders
Postby CumminsPower59 » Tue May 27, 2014 3:42 pm
Good score on those quads Andy. Those scramblers are pretty fun, especially the older two-stroke 400's...they flat out haul a$$. I ran Polaris machines for a long time, but my next one will be a Yamaha Grizzly 700. My Sportsman 800 was plenty powerful, but she was tubby at 800+ lbs, the Grizzlys are 150lbs lighter and way easier to maneuver on technical trails.
Postby dazedandconfused » Tue May 27, 2014 4:23 pm
That 4 stroke 500 screams. It has an aftermarket exhaust and has been rejetted. Its a quick sob and hard to keep the front end down.
