Postby Tacoclaw » Wed May 28, 2014 7:18 pm
I have the factory bypass forced closed with a metal tab, I found it to be completely worthless with my setup. The bypass I made has been functioning correctly according to my gauges. If it was stuck open I'd never have interstage boost and if it was stuck closed I wouldn't be able to break 15-20 psi manifold. I've done a few runs with it and never had a problem getting to 35-40psi manifold, with little to no interstage vacuum. Vacuum goes over -10psi on even a gentle roll on with it stuck closed, with a total smoke show to boot.
Rumble: Was it built on an Indian burial ground?
Postby CumminsPower59 » Wed May 28, 2014 7:25 pm
RumbleFish wrote:Got some pretty not good news about my house today. My attendance at the Iowa event is now questionable, as is the continued ownership of my truck. Stupid house...
That sucks Jeff, I hope everything works out well for you and your family.
Postby dazedandconfused » Thu May 29, 2014 4:55 am
That sucks to hear Jeff.
Postby RumbleFish » Thu May 29, 2014 6:06 am
Thanks guys. Hopefully my insurance will come through for some of it but who knows with those con artists.
Postby ellis93 » Thu May 29, 2014 2:35 pm
Jeff sorry your having an ordeal that involves your truck. I use to hate that,and when it happened I ALWAYS regretted it. Hope something happens that'll help you keep your truck.
Postby PToombs » Thu May 29, 2014 4:31 pm
Jeff, you're at least coming to Peru and getting this damn snowblower off my truck! ;)
Hope things work out for you.
Postby cmann250 » Thu May 29, 2014 5:10 pm
Warning: brief venting session.
My dad is a chronic borrower. I am a "two is one and one is none" person. Cue the tension. Today we had the KW pulling our gooseneck and a borrowed truck pulling a borrowed gooseneck to deliver some hay. I know nothing about the borrowed truck and since it's a GM with every light on in the dash, I figure the cluster is toast. Wrong, that gas gauge was accurate and dad ran it out. Gosh dang, that eats at me. I appreciate the concern for my old Dodge, but that strange kind of chit does not happen with it. We nailed a perfectly avoidable situation due to unfamiliarity.
End rant. :roll:
Postby PToombs » Thu May 29, 2014 5:22 pm
Andy and Ellis, the stiction preventer stuff is called Archoil 9100. Our resident ford guy said it costs less than Rev x. You need to use twice as much per oil change, but it works slightly better and and ends up costing about 1/2 less per oil change than the Rev x did.
I still think it would be cheaper to burn it or put in a Cummins. ;) :mrgreen:
Postby dazedandconfused » Thu May 29, 2014 5:45 pm
Mine will eventually get the Ducks heart and it will get a big block.
Postby bgilbert » Thu May 29, 2014 6:21 pm
Sell the truck after MM's. Can't cancel that hotel room this late! lol
Bill Gilbert
bgilbert
Postby 1STGENFARMBOY » Thu May 29, 2014 8:22 pm
My new grandson came tonight, 7 lb 2 oz, Ely Allen Dameron.
he will be sniffen diesel fumes and riding motorcycles in no time. :D
Postby RumbleFish » Thu May 29, 2014 8:28 pm
ellis93 wrote:Jeff sorry your having an ordeal that involves your truck. I use to hate that,and when it happened I ALWAYS regretted it. Hope something happens that'll help you keep your truck.
Me too. If it comes down to selling the truck or the srt, the truck loses. Theres only one reason id ever sell the srt and this house sure isnt it. Im supposed to have a sit down with my contractor tomorrow to see if we can come up with a realistic (affordable) plan B.
And yes Pete I will see you in peru at the minimum. Still not sure whats going on, I should know more tomorrow. Even if I do keep the truck, I may not drive it out. Something has kicked my mpg in the sack all of a sudden. 30mpg in a neon sounds alot better to my wallet than the 14-15mpg my truck is seeing.
Congrats Dar!
Postby RCCUMMINS89 » Thu May 29, 2014 8:38 pm
Congrats.!
Postby DMan1198 » Thu May 29, 2014 9:32 pm
That's really nice news on the grandson. My only news is I have the majority of the parts to swap to an s400 on jaeger. Just need clamps, pipe, and the turbo itself
Postby dazedandconfused » Fri May 30, 2014 2:57 am
Congrats on the grandson Dar.
