Postby ellis93 » Fri May 30, 2014 4:04 am
Congrats Dar :)
Postby DodgeFreak » Fri May 30, 2014 5:15 am
Congrats dar. Andy if the duck gets a big block what are you gonna put in it?
Postby dazedandconfused » Fri May 30, 2014 5:17 am
DodgeFreak wrote:Congrats dar. Andy if the duck gets a big block what are you gonna put in it?
I've been eyeing a few 440's around me but not jumped on anything. Im just ready for something a little different I guess. I'll put the Cummins in one of my Ford's.
Postby DodgeFreak » Fri May 30, 2014 6:03 am
Do you want a builder 440 or one ready to go?
Postby dazedandconfused » Fri May 30, 2014 6:37 am
I've been looking for a complete runner. I've actually been looking for a decent old camper. That way I could remove the cab and front end, build a wall and install a gooseneck and have a camper too. Lol
Postby 1STGENFARMBOY » Fri May 30, 2014 1:21 pm
my dad has an old Dodge motorhome with low miles, but I don't think it would do what you need...it has a 413 :shock:
Postby dazedandconfused » Fri May 30, 2014 1:37 pm
What will probably happen is I buy a camper and scrap everything I don't need
Postby ellis93 » Fri May 30, 2014 3:42 pm
:roll:
What a horrid idea. Leave the duck as is and add some power to it. Any retard can throw a big block in a small truck and make it move,cool factor is really low IMHO.
Postby dazedandconfused » Fri May 30, 2014 4:08 pm
It already moves the way it is. I get bored and tear sthi apart. :lol:
Postby PToombs » Fri May 30, 2014 5:17 pm
Dar, congrats you old fart! :lol:
I added it up the other night, I have about $275 in the plumbing for my twins, pipes, oil plumbing, fittings, etc.
Postby cmann250 » Fri May 30, 2014 5:55 pm
PToombs wrote:I added it up the other night, I have about $275 in the plumbing for my twins, pipes, oil plumbing, fittings, etc.
Rats! I came up with $500 for my side by side set up and shelved the idea. I had all metal and V-bands everywhere except the cold pipe's secondary end. Reinforced straight 4" boot there.
It's complicated. I'm busy and making money now, so I haven't dived into that project. If I had free time and was poor, I'd be all over it. :lol:
Postby oldestof11 » Fri May 30, 2014 5:57 pm
Congrats Dar!
Andy, I may know someone in Columbus IN that has a couple good engines.
Pete, that's it?
Postby PToombs » Fri May 30, 2014 6:18 pm
Jon, yup. A 4-5" adapter, 2 5" 90*, a 45, 2 3" 90*, some 2.5 and 3" straight pipe, a stick of 2.5 inch IC hose, a brass Y and some bends for the drains, (the Y was $25). A few flanges, clamps and a 90*3-4" boot. I forget how much the air filter was, I don't think that was in the receipts. Not too bad IMO.
Time spent, priceless! ;)
Only because my time isn't worth anything. :lol:
Postby RCCUMMINS89 » Fri May 30, 2014 7:55 pm
RCCUMMINS89 wrote:So today, I decided to take a stock high pressure lift pump spring... I then shortened it to an afc spring length, and then I opened it up to the same diameter. I then proceeded to use it for an afc spring. I could still benefit from a stronger spring, I honestly (without doing the math) never thought that it would come close to compressing.
Well, this turned out to be a pointless venture. :roll: Didn't really change a thing, It did slow my 30psi to 50psi fueling down though...... Like I needed help there. :roll:
Postby RCCUMMINS89 » Fri May 30, 2014 8:54 pm
I take that back... though 30 feels like it is helping.... I just turned my aftermarket fuel pin around (straight on the back) and can still hit 39-40 psi of boost.... WITH A 62/68!
I need more air.
