RCCUMMINS89 wrote:F these Cummins RC doo hickys.... mine will always be the king RC Cummins.
PToombs wrote:Caleb is selling his truck?![]()
dazedandconfused wrote:Does anyone know if the gears out of a Dana 60 rear will swap with a Dana 60 front? I have a 83 Ford D60 semi float rear with 3.55 gears and want to change the 4.10's in my front 96 Dana 60 in my Ford.
Philip wrote:dazedandconfused wrote:Does anyone know if the gears out of a Dana 60 rear will swap with a Dana 60 front? I have a 83 Ford D60 semi float rear with 3.55 gears and want to change the 4.10's in my front 96 Dana 60 in my Ford.
If your 60 in the front is a high pinion model that is a reverse rotation axle. A standard set of gears will not work.
I did a fast google search. It looks like that 96 is a high pinion axle.
dazedandconfused wrote:Philip wrote:dazedandconfused wrote:Does anyone know if the gears out of a Dana 60 rear will swap with a Dana 60 front? I have a 83 Ford D60 semi float rear with 3.55 gears and want to change the 4.10's in my front 96 Dana 60 in my Ford.
You are correct. I called Randy's this morning about it. Just shy of $700 for the gears and master kit.
