Postby DMan1198 » Tue Aug 12, 2014 7:47 pm
Indeed it will be. The 2 things I have to do before I set out are fix my damn oil drain again, so it won't leak on the trip, and build a sleeper for the bed, so I can have a proper bed to sleep in
Postby ellis93 » Wed Aug 13, 2014 4:40 am
diesel freak01 wrote:Ellis, try downloading tunein radio. You can normally find local stations or one that you like. Iheart radio is another ok one.
Tore the tractor down last night to fix an oil leaking head gasket. Turns out we got lucky and pulled it apart when we did. It was lifting the head and letting compression leak out. I guess 65 pounds of boost at 40 degrees of pump timing will do that. $1200 later studs new gasket and fire rings are on the way. Trying to have it back together by Thursday.
They use the data streaming portion of my plan ....which cost extra :roll:
I use to have unlimited streaming for listening to pandora and what not but slipped off into listening to a lot of news radio and such,so I unwittingly drop that when I switched phones and was told by the sales associate that an fm radio was on the iPhone.
You just can't imagine the schit I raised at that store when I figured out what was up :bom:
Postby Black93 » Wed Aug 13, 2014 8:18 am
Has anyone seen this before? It's a DPS manifold that's developed a small hole.
Black93
Postby RCCUMMINS89 » Wed Aug 13, 2014 9:29 am
Looks like a very thin manifold
Postby Black93 » Wed Aug 13, 2014 12:57 pm
The pic makes it look bigger than it really is and makes it look like it comes straight out. It's angled towards the rear. I didn't buy it new, but I'm still gonna contact DPS and see if anyone else has had this happen.
Black93
Postby PToombs » Wed Aug 13, 2014 4:50 pm
DMan, make a frame that fits in the stake pockets and throw a tarp over it, instant tent. I also thought about getting some 3/4 inch PVC and just bending it from 1 stake pocket to the other for the covered wagon look. It will be cheap, store easily and set up easy too.
Postby DMan1198 » Thu Aug 14, 2014 8:41 am
I think that's what I'll do Pete. Then fit the comfiest mattress I can in there and I'll be set
Postby PToombs » Thu Aug 14, 2014 4:40 pm
I meant put the cover up when you get there, if it rains on the way your mattress may not be so comfortable. ;)
Postby DMan1198 » Thu Aug 14, 2014 4:46 pm
I might figure some way of making it foldable, and do it so it looks like a tonneau cover folded down. If I do it right it should be waterproof
Postby ellis93 » Thu Aug 14, 2014 6:05 pm
Come 12 o'clock tomorrow,I'll be 9600$ richer and down by one ford :jumpsmile:
Thats 3100$ profit.....yes I put too much into it,but the truck made it seem it was worthy of the extra effort ;-)
Postby DMan1198 » Thu Aug 14, 2014 6:40 pm
Hooray Ellis. Just thinking about getting rid of a ford gives me a warm fuzzy feeling
Postby diesel freak01 » Fri Aug 15, 2014 12:33 am
Well pulled again tonight. Paul pulled the light class and the steering cylinder popped the tie rods off. Little welding and back up and running. I pulled the heavy class. Had a good hook going was a little swervy but ok til 280 feet and popped the hub again. It ran better than it ever has. Can't wait to see the data on what it did. Then on the way home a friend had Toter trouble. He uses an IH 190 to haul his Massey on. Block decided it didn't like where the rod was so it came out to say hello. Ended up pulling the truck home with the hot 1155 Massey. Made for a long and eventful evening.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby hemislave » Fri Aug 15, 2014 4:34 am
Sounds like a long night,Did you pull at Meigs co.fair?
85 crew cab 1st gen ve pump tweaked a lil. 4:10s auoto o/d gauges boost,pyro. 16cm exhaust housing .285/75/16 nitto terra grapplers,rebuilt a518 w/a decent torque converter.
hemislave
Postby diesel freak01 » Fri Aug 15, 2014 6:46 am
Yes. Was a good pull but went way late.
diesel freak01
Postby hemislave » Fri Aug 15, 2014 7:39 am
Usually does,but they put on a pretty good show.Only place left in this area that still pulls Modified 4wd trucks.
hemislave
