Postby DodgeFreak » Mon Sep 08, 2014 6:00 pm
happy bday Ellis.....been gone a few days and miss 10 pages......anything worth noting?? cause I'm not going to go back and read through it all lol.
Postby dazedandconfused » Mon Sep 08, 2014 6:15 pm
Happy Birthday Ellis. If your lucky Levi will pop out of your cake. :mrgreen:
Postby DMan1198 » Mon Sep 08, 2014 6:16 pm
Happy birthday Ellis.
Postby oldestof11 » Mon Sep 08, 2014 6:19 pm
Happy birthday Ellis!
Postby ellis93 » Mon Sep 08, 2014 6:28 pm
Appreciate the wishes guys :thumright:
Postby AHineman » Mon Sep 08, 2014 7:54 pm
dazedandconfused wrote:Happy Birthday Ellis. If your lucky Levi will pop out of your cake. :mrgreen:
:puker: :pukel:
That'd be a terrible way to start a party. :lol:
Happy birthday!
Postby diesel freak01 » Mon Sep 08, 2014 8:42 pm
Happy bday Ellis.
Just pulled the data logger. 69.28 psi and 1652 degrees at the cylinder. 850 psi of water injection pressure. With the leaking head gasket the motor got to 248 degrees after the run when it pushed the water out. I think if I could have stayed straight it would have been a hell of a pass. Might be starting to guald the differential which caused the sudden left turn in addition to the brakes. Might see this weekend at the next pull.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Philip » Tue Sep 09, 2014 5:46 am
Tacoclaw wrote:Dude finally faxed over what seems to be causing the confusion. I'm gonna triple-check #'s with JQmile since he swapped one in the Rust Bucket, then trade it for the 4:10 down.
The 3:07's use the 5/8's offset from what I have heard. But they use the 4:10 down carrier to get the spacing needed for the large pinion. Here is a pic of a 3:07 pinion beside a dead 3:54 pinion.
Hea Ike here is a pic of that bent 70 I replaced a long time ago. Look at both axle tubes to the level.
Postby DieselDays » Tue Sep 09, 2014 6:33 am
my first gen recently got the "death wobble" i heard these work pretty well http://www.custom-diesel.com/cummins/dodge-steering-stabilizer does anybody else have a second opinion on this ?
DieselDays
Postby DMan1198 » Tue Sep 09, 2014 9:49 am
Those don't fit 1st gens. Our entire steering setup is different. You may want to look at the bracket holding the steering box though as they're notorious for cracking. Also check everything else on the front end for wear
Postby BC847 » Tue Sep 09, 2014 10:50 am
DieselDays wrote:my first gen recently got the "death wobble" i heard these work pretty well http://www.custom-diesel.com/cummins/dodge-steering-stabilizer does anybody else have a second opinion on this ?
Learn your product Brad. :roll:
Postby ellis93 » Tue Sep 09, 2014 11:27 am
Anyone know the width difference between a 3/4 2nd gen axle and a 1 ton dual rear 1stgen axle?
Postby Tacoclaw » Tue Sep 09, 2014 12:09 pm
I know the 2ndgen D70's axle shafts are 2" longer than a comparable 1stgen D70, thanks about it. :lol:
Postby CumminsPower59 » Tue Sep 09, 2014 2:08 pm
Philip wrote: Hea Ike here is a pic of that bent 70 I replaced a long time ago. Look at both axle tubes to the level.
That's impressive! :lol:
Postby ellis93 » Tue Sep 09, 2014 5:08 pm
Tacoclaw wrote:I know the 2ndgen D70's axle shafts are 2" longer than a comparable 1stgen D70, thanks about it. :lol:
Then the housings are probably 4" longer then?
I'm only interested in knowing this because I may just break down and dual the dodge,including the Dually rotors/hubs for the front.
Actually a measurement from someone's dually axle will suffice,as I can measure one of the two second gen trucks axle I have. :)
Backing plate to backing plate.......
