Postby cmann250 » Sun Jan 19, 2014 2:17 pm
A friend of mine wants help with an Allison. This will be a new experience for me.... Willingly working on a GM product :lol:
I wonder what tricks GM engineered into an Allison to make it hard to take out.
Postby dazedandconfused » Sun Jan 19, 2014 2:31 pm
The computer has to be reflashed when you put it back in so just a heads up.
Postby cmann250 » Sun Jan 19, 2014 2:37 pm
dazedandconfused wrote:The computer has to be reflashed when you put it back in so just a heads up.
Does a dealer do that or can he do that with EFI live?
Postby dazedandconfused » Sun Jan 19, 2014 2:39 pm
Dealer can do it or anyone with a TechII but idk about EFI live
Postby cmann250 » Sun Jan 19, 2014 3:27 pm
Does that mean it doesn't move until it's reflashed or won't shift right or it can't be driven to town to get reflashed?
Postby dazedandconfused » Sun Jan 19, 2014 3:35 pm
Last one I messed with wouldn't even start.
Postby Philip » Sun Jan 19, 2014 3:45 pm
dazedandconfused wrote:Caleb have you hear what caused this?
http://www.wishtv.com/news/local/i-65-c ... le-crashes
Look at the vido. There are a pair of 4 wheelers tangled up in front of the pile up. Most likely they caused it.
Postby RCCUMMINS89 » Sun Jan 19, 2014 3:49 pm
So, I finally (after a year and a half).... took my darn thermostat out and turned it around (I wasn't paying attention and put the thing in upside down when I o ringed the head). Took about 15 minutes and my truck no longer fluctuates constantly on the heat gauge.
The things I put off sometimes on my truck, just astounds me. LOL.
Postby CumminsPower59 » Sun Jan 19, 2014 4:52 pm
I thought I put it in correctly...the jigglers are on top, correct? I'm kinda getting sick of the swings, I pulled my cardboard winter front, as the damn thing overheated on me while I was going down the interstate...in -10 temps.
Postby RCCUMMINS89 » Sun Jan 19, 2014 5:05 pm
I have one little "jiggler" (if that's what they are called) and yes it goes on top.
Postby txs » Sun Jan 19, 2014 9:20 pm
my 98 frt is giving me some problems. When starting it acts like its only hitting on a couple, when it does finally catch it runs rough, smokes like a 3208 cat and then after about 2 or 3 minutes it cleans up and is fine till you shut it off and let it sit overnight. I don't think it's a cold start thing, it even does it at 60*
txs
Postby ellis93 » Mon Jan 20, 2014 4:34 am
Injector(s) or timing. I'm having the same issues out of my conversion motor,but only cold or if it sits forever.
Postby Tacoclaw » Mon Jan 20, 2014 5:59 am
It's easy for the timing to slip on the P-pump trucks, not sure why they decided to take the key out of them. :?
Postby dazedandconfused » Mon Jan 20, 2014 6:08 am
ellis93 wrote:Injector(s) or timing. I'm having the same issues out of my conversion motor,but only cold or if it sits forever.
That's the way my truck would act when the timing was retarded.
Postby CumminsPower59 » Mon Jan 20, 2014 6:53 am
RCCUMMINS89 wrote:I have one little "jiggler" (if that's what they are called) and yes it goes on top.
I'm fixing to take it out and remove that jiggler...or go try a Gates unit. The thing rarely sits at a constant temp...swings back and forth almost constantly on my 33 mile trip to work.
