Postby dazedandconfused » Tue Sep 23, 2014 5:56 pm
My crew cab is just sitting there begging for a Cummins. The only one of my 3 Ford's with a engine is the dump truck. Lol
Postby txs » Wed Sep 24, 2014 5:06 am
Would a turbo off a 97 or so p pump motor be too much for a 4bt? This 4bt has the same exhaust flange as first gen dodges and it looks like its gonna put the exhaust right into the firewall, the 2nd gen turbo outlet angles down.
txs
Postby DMan1198 » Wed Sep 24, 2014 9:00 am
It'll be a little laggy, but it should work just fine
Postby Tacoclaw » Wed Sep 24, 2014 9:32 am
Don't they use an HX35?
You'd be worse off than a 1stgen turbo, the HX's are 'gated so they stick out an inch farther. The piece oughta clamp right to a 1stgen turbo though, right?
Postby CumminsPower59 » Wed Sep 24, 2014 10:26 am
I thought a fair share ran HX 30's, but I could be wrong....
Postby oldestof11 » Wed Sep 24, 2014 3:20 pm
4BT's had HX30's and later HE221 or HE211.
Postby PToombs » Wed Sep 24, 2014 5:10 pm
Tacoclaw wrote:Pete, I'm apparently not your FB friend,
I can fix that, but you might regret it! :lol:
Postby Tacoclaw » Wed Sep 24, 2014 5:58 pm
My only regret so far in life is not knowing more of the day-to-day of Peter Toombs. :cry:
Postby AHineman » Wed Sep 24, 2014 6:16 pm
Tacoclaw wrote:My only regret so far in life is not knowing more of the day-to-day of Peter Toombs. :cry:
I can think of a few more things you should regret. :P
Postby DMan1198 » Wed Sep 24, 2014 7:13 pm
Well he doesn't seem to regret the big girls, so what else is left?
Postby DMan1198 » Wed Sep 24, 2014 7:23 pm
On another note I'm stumped and next to frustrated on the vibration jaeger developed around this time last year. Now I've eliminated it being the tires, the steady bearing and the front driveshaft, so it's either axle u-joints or wheel bearings
Postby MMeier » Wed Sep 24, 2014 7:42 pm
Have to ask, WTF is a steady bearing ?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby Tacoclaw » Wed Sep 24, 2014 7:56 pm
I assume he means the pillow block that supports the middle of a 2-piece driveshaft.
Postby DMan1198 » Wed Sep 24, 2014 8:49 pm
That's an affirmative on what Levi said
Postby matthewh » Thu Sep 25, 2014 2:48 pm
Carrier bearing, at least that's what we always called it.
Anybody on here familiar with bobcat skid steers? I'm trying to either find, buy, or build a snow pusher box, and having issues identifying the quik attach? The dealer cant seem to tell me how far the "Bob-tach" style quik attach goes back, so I'm leery of buying a used pusher box, or attachments in general until I figure out what I have. For reference, its a late 70's/early 80's Bobcat 610
matthewh
