Postby dazedandconfused » Thu Sep 25, 2014 2:51 pm
Post a pic of the attachment plate on it and some measurements.
Postby matthewh » Thu Sep 25, 2014 3:02 pm
Will do, maybe be the weekend before I get out to the shop, but pre winter work on the thing is on the list
matthewh
Postby PToombs » Thu Sep 25, 2014 3:24 pm
I had to figure out what a steady bearing was too. I got it by the way he was talking about it.
Matt, I know 90's and up are all the same, not sure about that far back.
Postby matthewh » Thu Sep 25, 2014 4:07 pm
Its been difficult. Find conflicting info about it, some Sa there the same, others say the lower pins are narrower, so you have to move them out to work with newer attachments. Plus, throw in the chance the loader setup may have been replaced at some point.
Like Andy said, ill just have to get some measurements and pics, and go from there
matthewh
Postby dazedandconfused » Thu Sep 25, 2014 4:13 pm
I think it was 86 or 87 they went to the universal mounting plates. I know we had a early 80's and some attachments would work but others would.
Postby cmann250 » Thu Sep 25, 2014 4:59 pm
If its just the width between the pins that is different, burn new holes in the attachment. Seen it done before :lol:
Postby dazedandconfused » Thu Sep 25, 2014 5:50 pm
I believe the height of the older machine mounts was smaller. Its been 15 years since we messed with it though.
Postby PToombs » Fri Sep 26, 2014 5:46 pm
Caleb voiced my thought on the issue. It's easy to burn 2 more holes, just measure twice and cut once. If the rest of the measurements are the same. ;)
Postby DMan1198 » Fri Sep 26, 2014 6:51 pm
Just don't do the "I cut it twice, and it still doesn't fit"
Postby Tacoclaw » Fri Sep 26, 2014 8:30 pm
"I cut it twice, it's still too short."
Postby AHineman » Sat Sep 27, 2014 12:56 am
Tacoclaw wrote:"I cut it twice, it's still too short."
---What God said when he made Levi. :P
Postby bmoeller » Sat Sep 27, 2014 6:08 pm
Have a SERIOUS low power issue with my ol 93. Was suspecting the CAC was bad. Finally got what I needed to pressure check it. I was right. Shot to hell. Ordered a new one................... they sent a 2nd gen cooler. :evil: Decided to check the CAC on my crew cab truck. That one leaks, too! :evil: I can't win! :roll:
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Tacoclaw » Sat Sep 27, 2014 7:35 pm
Swapped in the 4:10 Detroit tonight, it's a long story and I'm typing it out on my GF's phone since I dropped a 40lb press spacer on mine, so that'll have to wait.
Short story is that not only did the 4:10 work, but it used the exact same amount of spacers that the other carrier did and put it right into backlash spec. 8)
I'll give the full story when I get to a computer/find a new phone.
Postby DMan1198 » Sat Sep 27, 2014 8:03 pm
So when I changed the idlers on the front end of jaeger a squeak/ticking noise was noticed coming from the valvetrain, so I checked my valve lash today. Somehow #1 intake had picked up 11 or 12 thou of clearance. All the rest were good. I also switched from the 1.1a/r to a .9 on the 480, so I'll see how that affects spool up, and driving characteristics
Postby cmann250 » Sun Sep 28, 2014 5:42 am
It is harvest time. Give equipment space on the roads and just assume every steering wheel holder pulling an ag hopper is over weight. :lol:
