cmann250 wrote:I hate GM. I hate Allison transmissions. I hate having other people do work for me.
That is all. Over and out.
just cause you don't know how to work on them....
1STGENFARMBOY wrote:just cause you don't know how to work on them....![]()
cmann250 wrote:dazedandconfused wrote:You having fun with that truck Caleb?
Had fun. The transmission out now and I'm waiting around for this local diesel "expert" to rebuild it. An Ally plus transfer case weighs a lot, but not too much to manage. I should have said "F" it and taken the transfer case off, but the "expert" said that wasn't necessary. Well as it sits bolted up, the transfer case sits a few inches over the torsion key cross member. So after about a dozen tries of letting the front down and maneuvering the tail up/down, back/forth, and left/right, we had it on the ground. The starter has to come out to get the converter bolts, dumb. And the starter sits under 2 inches from the passenger side exhaust manifold with no sort of heat shield that I saw, dumb again.
I should have "Nope, don't want anything to do with it" but I wanted the Allison notch in my belt. That's what greed gets you.
ellis93 wrote:That's an hour job......son
On a lift,with a transjack,and the torsion tool
cmann250 wrote:ellis93 wrote:That's an hour job......son
See sig
