Do i need airbags
Re: Do i need airbags
Postby PJ 3 » Sat Oct 23, 2010 5:15 pm
The only thing I see is one hell of a nice camper sitting on a beauty first gen with well fabed overloads :P
Now that's first class retirement Darwin !
Pete
1992 W250
PJ 3
Postby 1STGENFARMBOY » Sat Oct 23, 2010 5:35 pm
Thanks Pete i can only sit back and wish my life away because i want to retire (NOW).
Dar
Postby PJ 3 » Sat Oct 23, 2010 5:37 pm
1STGENFARMBOY wrote:Thanks Pete i can only sit back and wish my life away because i want to retire (NOW).
Dar
Don't we all.......... :?
Pete
1992 W250
PJ 3
Postby ellis93 » Sat Oct 23, 2010 7:20 pm
Have you thought about something in between the spring and stops. Something to help the two side by each other like a piece of plastic. May keep any noises down or binding.
Postby 1STGENFARMBOY » Sat Oct 23, 2010 8:00 pm
Yeh ellis i'm gona do somthing there, first i need to tweek the distance they are from the stops,
because they will hit every now and then when i go over a sharp bump when empty, i'm gona grind off a little
of the spring then try to figger out what i'm gona put between them.
Dar
Postby Richie O » Sat Oct 23, 2010 8:09 pm
ellis93 wrote:Have you thought about something in between the spring and stops. Something to help the two side by each other like a piece of plastic. May keep any noises down or binding.
I thought that as well. As far as the bumping when hitting ruts, Both of my ton dump trucks do that. With the dump body empty its like yours and will jump you in the air when it hits on them. A real tight shock would help some with that.
Postby ellis93 » Sat Oct 23, 2010 8:22 pm
I know this is gonna sound funny but my truck rides better loaded up till its over loads are hitting. I can hit a bump running empty and it jars pretty bad. Loaded or pullin a loaded trailor it rides like a caddie, well till the trailor starts jerkin anyway. :?
Postby 1STGENFARMBOY » Sat Oct 23, 2010 8:42 pm
Richie... you are exactly right my rear shocks are junk and need replaced, and thats on
that long list, you know the one that only gets longer. and my truck rides nice loaded
also.
Darwin
Postby Mark Nixon » Sun Oct 24, 2010 8:11 am
My "heavy" truck rides nice ALL the time.....empty. :roll:
Of course, with an 18 foot wheelbase and the front springs nearly loaded at the max, and an empty weight of 9,000 pounds, things tend to ride pretty smooth, anyway. :lol:
BAG IT!!! :twisted:
Postby 1STGENFARMBOY » Sat Oct 30, 2010 7:21 am
This is kinda off the airbag thing but it's for the same reason as bags, i needed (wanted) to try some load range E tires but with 16.5
wheels i can't readily find a tire that looks like anything for my wheels so i scored these on craigs list this week for $100.00 all 4 with
3 caps and the original tires (load range E) from a 2007 2500 with 1/2 tread , they are on with no spacers but they are very (CLOSE) but i drove it to work
yesterday and no problems, theres maybe 1/4 to 3/16 in between the wheel and tierod end.
Darwin
Postby Mark Nixon » Sat Oct 30, 2010 7:41 am
Those steel wheels do look pretty nice on there, Dar.
3/16" is as good as a mile, but you also must have tight bearings on the hubs.
Not so sure how they'd clear on a 2wd.
Postby 1STGENFARMBOY » Sat Oct 30, 2010 8:12 am
Thanks Mark...they don't look hideous but i'm not much for blingy things, but i bought them for a need and
they will do for that. I'm gona try it out next weekend and haul that beast of a camper on a little trip.
Dar
