Thanks,
-Matt
cmann250 wrote:I'm thinking of a true split rim where the rim has two halves that together make up the width of the rim. There's a lip in the center of the rim that holds them together when the tire is inflated.
Are you thinking of a 2 piece rim where the rim and tire are separate from the big heavy (usually 5 spoke) hub? They usually attach with wedges and bolts. This kind is what our mobile home frame trailer has as well as others and it's fine with DOT.
meby wrote:Thanks.
I priced out tires yesterday and a local shop has them mounted for $78 each for 12 ply. I thought that sounded like a good deal. Much better then online prices even.
dazedandconfused wrote:
Check mobile home dealers i bought 6 for $200.
