Talk about rowin some gears!
Postby Raymo » Mon Dec 22, 2008 8:43 am
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby RumbleFish » Mon Dec 22, 2008 8:54 am
http://www.youtube.com/watch?v=2CG0Yx3c ... re=related
here is the incab view. sometimes id like an extra gear or two, but 5 extra, no thanks!
Postby MMiller » Mon Dec 22, 2008 9:16 pm
I'd like to see the underside of that truck. I read where is has a rockwell t-case. I'm thinking that trans would hold up to any towing conditions. Might not be so good for grabbing gears in the mud though.
Michael
MMiller
Postby gear jammer 91" » Mon Dec 22, 2008 10:01 pm
With a strong cummins he should be able to start out in high range when empty, or at least skip every other gear. The nice thing about a 10 speed is the lack of needing the clutch to shift. Personally, I want the 13 speed eaton/fuller out of the kw I drive at work. 8)
01 LB7
gear jammer 91"
Postby KTA » Tue Dec 23, 2008 9:24 am
I am putting a 7 speed roadranger in my project 1000rwhp street truck and hooking it to a rockwell t223 transfer case. I am concearned about the ability of the t-case to take the power, but I think since the thing will be soo light compared to what it was designed for that it might be OK. Fitting the big fuller is going to be a bit of a problem though as even with a 3" body lift its still going to take some serious hammer time to the floorboard to get it in there. 8)
Postby Raymo » Tue Dec 23, 2008 10:33 am
Oooo KTA that sounds like fun, I was offered a 7 speed over the summer but the dude wanted 1800 for the trans by itself, and I dont even have an engine yet :mad:
Raymo
Postby MMeier » Thu Dec 25, 2008 6:43 pm
Now that 10 speed is what i want for my truck !!!! :D
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby peobryant » Fri Dec 26, 2008 12:55 am
While you're wishing for that 10spd, I would kill to have a 5spd...
Prefrerably an NV-4500, but we'll see how that works out...
Postby Diesel Dan » Sun Dec 28, 2008 8:19 pm
all i have to say is that i will look into that swap when the tranny in mine goes and i will hope to have lots of money at that point to fund the swap
WOW thats cool
Diesel Dan
1992 cummins, 350, single cab, 8 foor bed (kinda), manual, 4x4
Right now Very ugly but its a cummins!
Diesel Dan
Postby dpuckett » Fri Jan 02, 2009 10:58 pm
I agree with Gear Jammer- he should be able to start on the high side, ro at least in 4th/5th. Even empty driving a big rig with a 290 or 330, I start in 4th empty- still a tare of 28-30K. Unless Bowtie Boy was just showing off.
I wouldnt want an Eaton/Fuller unless I could get one of the double OD trannies- useless with only direct, even if yougot ahold of some 3.07 gears, and a single OD isnt a great improvement over direct. But it would be great for towing super heavy.
Daniel
Postby KTA » Sat Jan 03, 2009 6:30 am
My 7 spd has the same overdirve ratio as a NV4500 so I don't think I will have any problems.
