Sooo its finally happening!
Postby Raymo » Sat Jan 17, 2009 12:07 pm
I sold my pride and joy big block today, which was heartbreaking... but I now have enough to finally buy a *^%%$%# Cummins!!!
I have a question tho. the donor I'm lookin at has a 727, everything works great and its a good price, but how is milage gonna be with my 4.10's and 33's? About the first month it will be horrible cause of my foot... but what about till I get a 5 speed?
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby TWorline » Sat Jan 17, 2009 3:17 pm
Then it will be bad for another month because of you foot! ;-) I have 33's on mine with 3.54 and get between 17 and 20 MPG. With 4.10 I would guess 15 - 18.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Raymo » Sat Jan 17, 2009 9:42 pm
hell, I can live with that. Thanks Tim!
Raymo
Postby oconnellrb » Sat Jan 17, 2009 10:09 pm
Are you putting the cummins in the chevy ? You should be able to use the nv4500 with the cummins.
oconnellrb
Postby Raymo » Sun Jan 18, 2009 9:42 am
Man I wish, its the older 4500, annndddd its got the super low granny gear so I dont think I can change the input shaft. If I remember right its the 96 and newer 4500's from chevys that you can change over, mines the original 93
Raymo
Postby Begle1 » Sun Jan 18, 2009 9:55 am
You guys talk like you keep the foot to the floor of a first gen because they're fun to drive.
On a stock first gen, you put the foot to the floor because you want it to move...
They're the slowest things on the road stock.
Postby GO OVRIT » Sun Jan 18, 2009 10:42 am
Begle1 wrote:You guys talk like you keep the foot to the floor of a first gen because they're fun to drive.
Yea....but why in sam hill would you leave it stock? :scratch:
GO OVRIT
Postby Raymo » Sun Jan 18, 2009 11:09 am
thats what I'm sayin, it'll be tuned up before it leaves the donor!
Raymo
Postby RumbleFish » Sun Jan 18, 2009 11:28 am
Begle1 wrote:They're the slowest things on the road stock.
not true. ever driven a gasser 1st gen?
Postby burnt_servo » Sun Jan 18, 2009 12:13 pm
how about driving a stock gasser 1st gen on propane ........ i swear i could get out and walk faster some days .
'93 w250 .... stock ...
burnt_servo
Postby RumbleFish » Sun Jan 18, 2009 1:29 pm
ill see that, and raise ya one...my 1st truck was a 81 with a slant six. with the od trans. i was regularly passed by elderly in wheelchairs.
Postby GO OVRIT » Sun Jan 18, 2009 6:38 pm
RumbleFish wrote:ill see that, and raise ya one...my 1st truck was a 81 with a slant six. with the od trans. i was regularly passed by elderly in wheelchairs.
:D The leaning tower of power :D
I had an 89 with a 3.9 v6 and 35s...I actually won money sand drag racing in it. You gotta love bracket racing. I wound up replacing it with a 318 out of a boat. I took someone elses word on which direction it turned......
When I couldn't get it started I pulled the distributor cap and watched the rotor turn backwards. :shock:
GO OVRIT
Postby Richie O » Mon Jan 19, 2009 10:55 am
Nice, you had the pricey reverse rotation one out of a dual engine boat. :)
Postby burnt_servo » Mon Jan 19, 2009 1:49 pm
i'll raise you a 318 on propane / 518 tranny , BUT with at least 2 burnt valves :D ......
i'm hoping i can limp it through a couple more mounth so it's warmer out when i fix it .
burnt_servo
Postby dpuckett » Mon Jan 19, 2009 5:29 pm
The 1990 I had for a few months was about the same as a stock CTD- but it also weighed a ton less than a stock CTD.
How about a 1983 1 bbl carbed Ford Ranger? Top speed was around 70, and it took all of 1.5mi to get there.
Dan
