Throttle Linkage
Throttle Linkage
Postby peobryant » Sun Feb 08, 2009 6:39 pm
Well, while I was changing the oil and filters today, I decided I would try out the throttle linkage mod. I moved the throttle linkage up one hole and the springs down.
I have to say, it did make my truck a whole lot more responsive, but I'm not sure I have full throttle travel. Is there an easy way to check this? Also, it seems like the RPM's hang right above idle for about 1/2 a secong when I let off, and then lower back to idle. Any thoughts?
All in all, I think it is a pretty good, and easy little mod. It makes my close to stock truck a whole lot more fun to drive. 8)
Postby mprmn08 » Sun Feb 08, 2009 8:02 pm
have someone hold the pedal to the floor and then you check to see if the throttle moves all the way. if it doesnt then you know its not full travel. :D
mprmn08
Postby peobryant » Sun Feb 08, 2009 8:05 pm
:oops: seems easy enough. Thanks.
Postby Renigade » Mon Feb 09, 2009 3:48 am
Tell an old dummie how to do this if you don't mind. :lol:
1993 1st gen BHAF -Smoke screw 2.5 turns, star wheel 2.5 turns. Fuel screw 1.25 turns, fuel pin ground.
Renigade
Postby peobryant » Mon Feb 09, 2009 2:03 pm
Renigade wrote:Tell an old dummie how to do this if you don't mind. :lol:
Do you need to know just the gist, or do you want pics and all the sizes of the tools needed?
It's a pretty easy mod, but I think my RPM's hand just a little above for less than a second, and it sounds like my idle is higher?
Postby SChandler » Mon Feb 09, 2009 3:46 pm
Did you adjust the length of the rod after moving it over to the next hole? It sounds like the rod is a hair long and is holding the throttle slightly open from your idle setting.
SChandler
Postby Renigade » Mon Feb 09, 2009 4:06 pm
91 a few pictures and a list of the tools would be great since these VE pumps are new to me. :D
Renigade
Postby peobryant » Mon Feb 09, 2009 8:39 pm
Renigade wrote:91 a few pictures and a list of the tools would be great since these VE pumps are new to me. :D
I'll have to take the pics either tomorrow or the next day, but the only tools you will need are two wrenches (don't recall what size) and a screwdriver. I'll have to redo it in my head while I'm taking the pics for the write up.
Postby Renigade » Tue Feb 10, 2009 3:38 am
Thanks ;)
Renigade
Postby peobryant » Fri Feb 27, 2009 10:26 pm
Sorry, I completely forgot about this... :oops:
Richie posted a picture that basically explains what you are supposed to do, I will see if I can find it.
Postby peobryant » Fri Feb 27, 2009 10:55 pm
That is what it should look like when you are finished. It's a very straightforward mod. Enjoy. 8)
Postby Renigade » Sun Mar 01, 2009 6:37 am
Thanks for the picture. I did this change over and it helped tremendously
Now I am waiting on my 366.
Renigade
Postby peobryant » Sun Mar 01, 2009 9:00 pm
Renigade wrote:Thanks for the picture. I did this change over and it helped tremendously
You're going to love that little spring as well.
