DennyT's 1st Gen Performance Website
Postby peobryant » Wed Apr 29, 2009 12:18 pm
Dennis is in the process of making a 1st Gen specific performance site. Right now he only has his pin for sale, but he lists turbos, cams and injectors as coming soon. I hope it works out.
www.dennytperformance.com
Postby Begle1 » Wed Apr 29, 2009 12:46 pm
Cool. Good for him.
Postby 93_Fummins » Wed Apr 29, 2009 1:48 pm
Wish I would have known about DennyT before I dove into tweaking my rig... :( I like the look of the Stage II pins better than the DDP pin I bought...
93_Fummins
Postby KTA » Wed Apr 29, 2009 6:47 pm
I wonder if a Denny T pin will pick me up 50 hp over my ground stocker? :-)
Postby peobryant » Wed Apr 29, 2009 6:52 pm
KTA wrote:I wonder if a Denny T pin will pick me up 50 hp over my ground stocker? :-)
:roll:
That reminds me. Brian, how much rwhp did you make with your twins and 12mm H/R? There are quite a few guys on the DTR that claim they are making over 500rwhp with the 12mm H/R and a huge single. :roll:
At this rate,we will have a VE with 1000rwhp in no time. :lol:
Postby swank » Thu Apr 30, 2009 5:48 am
'91 Cummins wrote:There are quite a few guys on the DTR that claim they are making over 500rwhp with the 12mm H/R and a huge single. :roll:
Do they even have trucks? That aren't sponsored by Tonka?
truck
swank
Postby burnt_servo » Thu Apr 30, 2009 5:14 pm
i thought it was mattel ...... but i could have heard wrong :D
'93 w250 .... stock ...
burnt_servo
Postby KTA » Fri May 01, 2009 6:33 am
I made 486 with my single and 488 with the twins uncorrected #2 fuel only on the stock 12mm pump. There is even video and dyno sheets posted to prove it!! What about those other guys with the 500+ singles, got any proof?
Postby soggy » Fri May 01, 2009 6:42 am
Yeah the last guy, with 527 had a sheet. He never did say if it was no 2 only or if there was w/m also.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby KTA » Fri May 01, 2009 7:03 am
Good deal. I am glad somebody has finally beaten my numbers from back in 2003. It looks like this is a built motor too, not like my 220,000+mi original short block and stock cam. I suspect that from the signitaure it had meth injection to pull those numbers that high in the rpm's, but maybe not. Anything is possible!
Postby peobryant » Fri May 01, 2009 12:27 pm
soggy wrote:Yeah the last guy, with 527 had a sheet. He never did say if it was no 2 only or if there was w/m also.
I suspect he was using W/M. He has been asked at least 4 times if he has used it, and is avoiding the question.
What did the guy with the 527rwhp run as a turbo? I know the other guy with 501rwhp claimed to run am S510 (I believe that is what he said.)
