Some of these items may be useful for 1st gen guys:
Black Friday 11/23- Cyber Monday 11/26
30% off Coupon code inj30off
90HP, 100HP, and 160HP -300HP nozzles and injectors 24v vp44
5x.013- 5x.016 nozzles and injectors 12v 1st gen VE or 2nd gen P-pump
89-93 injectors http://www.dieselautopower.com/ProductD ... 3&CartID=1
94-98 injectors: http://www.dieselautopower.com/ProductD ... 8&CartID=1
12v Nozzles
http://www.dieselautopower.com/product_ ... 3-5x13.htm
http://www.dieselautopower.com/product_ ... 3-5x14.htm
http://www.dieselautopower.com/product_ ... 3-5x16.htm
20 % off Coupon code inj20off
90HP vp44 nozzles http://www.dieselautopower.com/product_ ... 2-90hp.htm
100HP vp44 nozzles http://www.dieselautopower.com/product_ ... -100hp.htm
20% off Italian PDT Coupon code PDT20 -While supplies last
nozzles for 03-04, 04.5-07, and 07.5-12 6.7L
http://www.dieselautopower.com/ProductD ... d-Gen-5.9L
ARP Head Studs 8% off for Coupon code ARP8
247-4202 24v http://www.dieselautopower.com/product_ ... 7-4202.htm
247-4203 12v http://www.dieselautopower.com/product_ ... 7-4203.htm
10% off edge products Coupon code Edge10
Call in for these specials:
94-98 Aftermarket Injectors, No core required ($100 refund if you send in your cores)
5x.012 SAC $350
5x.013 $350
5x.014 $380
5x.014 SAC $400
89-93 Aftermarket Injectors, No core required ($100 refund if you send in your cores 7mm tip only. 89-91 9mm tip are not accepted)
5x.012 SAC $350
5x.014 SAC $400
Cummins/ Jacobs Exhaust Brake $550 98-02 manual trans
Free T-shirt with Airdog 100, 150 II165 Send us an email with your shirt size and order number
http://www.dieselautopower.com/SearchRe ... =10&page=1
Free T-shirt Smarty Send us an email with your shirt size and order number
HS Mini Max 901.55 and XRT 664.05 in stock
After our current stock is gone prices will likely go up about $60 as cost of product is increasing
http://www.dieselautopower.com/product_ ... 109005.htm
http://www.dieselautopower.com/product_ ... 109003.htm
