New from Washington
Stop in and say hi
New from Washington
Postby tmar253 » Mon Mar 19, 2012 10:39 am
Greetings
This is my first Cummins powered truck, I made the switch from Powerstroke and will never look back.
I had been looking for a 1st Gen Cummins for quite some time and the search is finally over. The truck has everything & more I was looking for except 4x4. The truck is pretty straight considering the age It has two dents on the driver side of the bed and some surface rust on the hood.
Here are a few pics
92 D350 Dually 5spd
187,000 miles
2 wheel drive
Dually diesel club cab
5 spd manual
2 speed auxiliary transmission /gear splitter ( Mitchell) over/underdrive for a total of 10 speeds
3.54 limited slip rear end
Intercooler
AC blows cold
Power windows & door locks
LE package
SS wheel simulators
On board air compressor
Jake brake ( needs to be looked at)
Thanks for looking, I will be spending quite a bit of time on here. Mods coming soon!!!
tmar253
Re: New from Washington
Postby CumminsPower59 » Mon Mar 19, 2012 11:07 am
Welcome! Good lookin truck!
Postby ellis93 » Mon Mar 19, 2012 12:34 pm
Welcome!
Postby fatty » Mon Mar 19, 2012 1:02 pm
Nice first gen! Where at in WA are you?
Postby Dieselwrencher » Mon Mar 19, 2012 1:27 pm
Man, that is a nice looking DRW! Nice score, and welcome to 1stgen.org.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
Postby pulltilbroke » Mon Mar 19, 2012 1:35 pm
Shoot thats a clean rig with some nice goodies!!
On the exhaust brake I'd be willing to bet the brake valve is siezed up. The Brake that was on my 93 had the same issue.
Welcome to 1stgen.
Postby tmar253 » Mon Mar 19, 2012 4:57 pm
Thanks guys for the comments! I will be doing the NV4500 swap in the next few weeks. The wiring for the jake brake comes up to the shifter for the high/low splitter and has an off switch. It looks as if there is some faulty wiring do to the fact the wire is melted, to many amps? Possibly... I'm from Tacoma... Future plans for the truck include P pump & Twins.
tmar253
Postby tmar253 » Mon Mar 19, 2012 5:00 pm
The body damage & rust will be fixed within the next week or so!!!
tmar253
Postby oldestof11 » Mon Mar 19, 2012 6:13 pm
How did I miss this one???
Welcome! Sharp rig!
Postby cmann250 » Mon Mar 19, 2012 6:43 pm
Welcome, like said before, nice truck 8)
Postby fastrabbit » Mon Mar 26, 2012 8:29 am
welcome.. Im also new to the cummins diesel just bought a 2wd auto.. Im in puyallup. twins would be sick
fastrabbit
Postby MikeRWC » Wed Apr 01, 2015 10:55 pm
Hey there, great looking rig! I have been looking for one of those Mitchell gear splitters. How do you like it? I'm not sure if you float gears but if you do, does it shift well without a clutch? dang hard to find those units in a direct over drive version.
1992 W250 club-cab Flatbed 3.54 gears 285-75r16 get-rag 5 speed 230k DAP 5X.011 injectors, H1C with 60mm GDS compressor and BD 16cm Exhaust, timing bump, pump tuned(ish), 4 inch intake with BHAF, 4 inch strait threw exhaust, tac, piro, psi gauges and a very fugly looking paint job.
MikeRWC
Postby RCCUMMINS89 » Thu Apr 02, 2015 2:22 pm
Welcome
Return to Welcome
