Newbie
Stop in and say hi
Newbie
Postby ihredneck » Thu Oct 04, 2012 10:02 am
I just joined this group and I'm excited to have found it! :D
I am the owner of a 1992 W350 Regular Cab that I've been doing a full restore on.
I stripped it down to the frame and have rebuilt everything...and I mean everything except for the engine sense it only had about 230k on it.
Right now it's in the shop getting all the dents pulled out and a fresh coat of paint, plus an undercoating of the Herculiner
The flat bed I just finished cutting the bad steel out and doing a restore on it and adding all LED lights
I'm now looking around for a 4" Turbo back, aftermarket air filter, 3200 governor spring, 60 lb valve springs, tweaking the smoke screw, bumping the pump, modifying the fuel pin and maybe putting some 90 HP injectors in. It's all hear say now until I get the body finished and back on the road.
Any suggestions or ideas are excepted as I want to use this truck but not abuse it!!
ihredneck
Re: Newbie
Postby cmann250 » Thu Oct 04, 2012 12:44 pm
Welcome! Sounds like you tackled the hard stuff first :D
Re: Newbie
Postby ellis93 » Thu Oct 04, 2012 12:51 pm
Welcome! Pics?
Re: Newbie
Postby dazedandconfused » Thu Oct 04, 2012 1:19 pm
Welcome
Re: Newbie
Postby W350Eddie » Thu Oct 04, 2012 1:29 pm
Hey fellow noob, I'm interested in seeing some of the pictures as well. Also, have you had any painting estimates yet? I'm trying to get a feel for pricing to get mine sprayed as well. I've heard in my local area $3000 for just paint and no body work and not spraying the bed...
W350Eddie
Re: Newbie
Postby tampabayBill » Fri Oct 05, 2012 6:17 am
Welcome !
Twins coming soon!
tampabayBill
Return to Welcome
